![]() | Home > Maintenance & Mods (L322) > EGR Delete photos ( update +1300miles) more miles |
Henda Member Since: 02 Aug 2018 Location: Gateshead Posts: 282 ![]() ![]() ![]() |
Following the post by ptaroni I fitted the egr deletes purchased from eBay with a good picture guide and instructions
Release the pollen filter housing two 13 mm nuts remove the engine cover first it's easier it should look like this Next release these pipes and sure up and away using a cable tie then loosen off the wiring around the egr pipes I found it easier to pop them out of there mounts you should end up looking like this Next loosen off the support bracket 4 bolts and push back You can now see the egr pipes it is a bit tight Remove the gauze sleeve and loosen the top two bolts and remove next using a small extension loosen the lower bolts There should a metal gasket that's holds the bolts so I didn't remove them but lifted out the pipe complete BE CAREFUL here remove the pipe make sure you get the o ring from the top CAUTION here as I found bits of plastic piping from the harness had fell down make sure it's debris free before you remove Now to refit using a magnet Just like this lower plate first do not over tighten It should look like these re place all the brackets wiring and check it's all secure Tools I used sockets 10 mm 13 mm ,t30 tork players small sockets 9mm not much more than that Some photos of the old and new bits And then start the engine and no emi light Only time will tell Overall not hard but fiddley to do take your time took me about an hour and a half including coffee and cig breaks and the photo shoot The kit comes with clear instructions but you'll need cable ties and use the new bolts which are Allen key style Cheers henda ![]() Last edited by Henda on 9th Mar 2019 10:39am. Edited 3 times in total |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6749 ![]() ![]() ![]() |
So there’s no EML with just the blanking and no EGR software delete?
As far as I can tell the egrs still work so may need a delete later but they are blanked off from the intake circuit
Just been out to start the FF in the cold morning air
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35545 ![]() ![]() |
wiki'fied |
Nice one cheers |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 491 ![]() ![]() ![]() |
Excellent write up and good news on the lack of EML. Have you read the codes to see if anything is throwm up at all that maybe wouldnt cause the eml to trigger? Also did you unplug the egrs from harness?? Thanks Current 2007 TDV8 Vogue Buckingham Blue |
No every thing stays connected I already have a egr fault low voltage I think so one of them wasn't working properly,my plan is to get a ecu delete if need be
Excellent so to reverse it in the future you just replace that pipe if needs be then too. Any noticable increase in mpg and running? Current 2007 TDV8 Vogue Buckingham Blue |
Kbald , yes reversal is as you say just put the pipes back in , careful though as I destroyed the first one trying to pull it out before releasing the bottom but the gasket holds the bottom bolts so be careful when removing and you can replace at any time
RS2000CUSTOM Member Since: 25 Apr 2013 Location: The Black Country Posts: 137 ![]() ![]() ![]() |
EGR modification/delete - Now an MOT FAIL !
SandySix Member Since: 13 Sep 2018 Location: Chippenham Posts: 44 ![]() ![]() ![]() |
Well maybe
Also the E24 limit can be affected by EGR and if an excess amount is measured then also a fail regardless if you can “see” a modified EGR or not 2009 - L322 5.0 S/C Autobiography |
gj88 Member Since: 10 Sep 2018 Location: West Midlands Posts: 213 ![]() ![]() ![]() |
Each car will be different but my last emissions test had me at just slightly above half of my limit. Unless removing the EGR doubles your emissions, or the tester can see through plastic, I can't see it being a problem. |
