![]() | Home > Technical (L322) > The odd chirrup 4.4tdv8 |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
No worries, i even took my first 4.4 to the dealers to have it checked! |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3811 ![]() ![]() ![]() |
http://www.fullfatrr.com/forum/topic38291.html
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1209 ![]() ![]() ![]() |
Thanks for the info Baltic Blue just read through the post looks like its a trip to the stealers as I also experience the hesitation with the throttle response.
careyba Member Since: 28 Sep 2013 Location: Coffs harbour Posts: 15 ![]() ![]() ![]() |
I have the same chirping noise on my 4.4 tdv8 when slightly backing off the accelerator. In my case, if I dont squirt a bit of throttle, the car revs will jump back and forward a couple of times quite noticeably.
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 512 ![]() ![]() |
Careba - Page 2 of this thread from Craig is the best answer (as above). Try the reversing up an incline suggestion to force the noise, if that's the noise it's normal they all do it. Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
The noise doesnt bother me. It is more the surging back and forward like it is hunting. Rocks the car back and forward if you dont catch it.
RRDunc Member Since: 26 Feb 2020 Location: Leicestershire/Warwickshire border Posts: 520 ![]() ![]() ![]() |
Don't blank off your EGR if you've got a 4.4 TDV8. The DPF regen process uses the EGR cooling as part of its cycle. Dunc. The life you have is the only one you'll get; make the most of it. --------‐--‐-----------------‐------------------‐--------------------------------------------------- 2012 4.4 TDV8 L322 Autobiography 2003 TD5 Oslo Blue D2 ES Premium Auto (with mods!) |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2640 ![]() ![]() |
Mine doesn't seem to do it anymore since having the PCM s/w updated to the latest level. I feel that the update that included fixing the hesitation at 110 kph while on cruise control included a few other improvements regarding the secondary turbo management especially on light throttle as gentle driving around street corners has improved significantly. |
The 4.4tdv8 released in Australia doesnt come with a dpf fortunately!
The PCM update can't be done using the IIDtool so mine was done by the local LR dealer. I had 2 other ecus updated for the total cost of $330 with the justification that the technician couldn't leave the vehicle to do other work for the 2 hour download/update duration.
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
Hi NorthernMonkeyJones,
Before anyone else says it…
KristoffL322 Member Since: 20 Jun 2022 Location: North West Posts: 27 ![]() ![]() ![]() |
Mine does it as well, I took a short video of it. Sounds like turbo flutter or turbo chatter to me. Back in the day when I used to modify cars this is the noise my turbos made if I didn’t run a dump valve. Air goes the wrong way past the spinning fan blades when you lift off the throttle and makes that noise. It got worse when I upped the boost with a remap.
It hasn’t always done that so something has changed or isn’t operating as it should. While it may not be a problem, surely it’s having an adverse effect.
