Home > Technical (L322) > The odd chirrup 4.4tdv8
Page 3 of 4 <1234>
No worries, i even took my first 4.4 to the dealers to have it checked! Embarassed Embarassed Embarassed
Post #494852 6th Nov 2018 11:32pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Pld118
perce
There is a software upgrade that will cure this hesitation for you
The fix came out 6 or 7 years ago
If you search the forum, you will find the bulletin number
Post #494940 7th Nov 2018 9:12pm
Baltic Blue
http://www.fullfatrr.com/forum/topic38291.html
This may help
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #494947 7th Nov 2018 9:21pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Thanks for the info Baltic Blue just read through the post looks like its a trip to the stealers as I also experience the hesitation with the throttle response.
Bow down Thumbs Up
Post #494975 8th Nov 2018 8:33am
careyba
Australia 2004 Range Rover HSE Td6 Epsom Green
I have the same chirping noise on my 4.4 tdv8 when slightly backing off the accelerator. In my case, if I dont squirt a bit of throttle, the car revs will jump back and forward a couple of times quite noticeably.
This feature seems to occur when driving into roundabouts, up hills in a low gear and backing off the accelerator and when in cruise at 110km/hr. Did anyone get to the bottom of this noise? Thinking about blanking and coding out my egr and pulling apart the plenum to clean sensors etc. However, any other guidance would be appreciated!
Post #576492 18th Dec 2020 7:57am
D3Jon
Cam-Tech-Craig wrote:
Can those of you who are concerned go out in your car and find an incline, then reverse up it covering your brake pedal with your left foot! Even partly applying your brakes to make you rev it higher. This should induce the secondary turbo chatter...
Just wondering if this is what at least some of you can hear? And this phenomenon is normal Shocked Thumbs Up
Careba - Page 2 of this thread from Craig is the best answer (as above). Try the reversing up an incline suggestion to force the noise, if that's the noise it's normal they all do it.
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #576500 18th Dec 2020 9:00am
careyba
The noise doesnt bother me. It is more the surging back and forward like it is hunting. Rocks the car back and forward if you dont catch it.
I will try the incline as well but pretty sure the surging is not supposed to happen.
Post #576502 18th Dec 2020 9:17am
RRDunc
England 2012 Range Rover Autobiography TDV8 Santorini Black
Don't blank off your EGR if you've got a 4.4 TDV8. The DPF regen process uses the EGR cooling as part of its cycle.
Dunc. The life you have is the only one you'll get; make the most of it.
2012 4.4 TDV8 L322 Autobiography
2003 TD5 Oslo Blue D2 ES Premium Auto (with mods!)
Post #576565 19th Dec 2020 12:50am
GraemeS
Mine doesn't seem to do it anymore since having the PCM s/w updated to the latest level. I feel that the update that included fixing the hesitation at 110 kph while on cruise control included a few other improvements regarding the secondary turbo management especially on light throttle as gentle driving around street corners has improved significantly.
Post #576567 19th Dec 2020 5:32am
careyba
The 4.4tdv8 released in Australia doesnt come with a dpf fortunately!
What did the PCM upgrade cost and is it a dealer only fix?
Post #576572 19th Dec 2020 8:43am
GraemeS
The PCM update can't be done using the IIDtool so mine was done by the local LR dealer. I had 2 other ecus updated for the total cost of $330 with the justification that the technician couldn't leave the vehicle to do other work for the 2 hour download/update duration.
For those with DPFs, a DPF regen keeps the EGR valve closed when it might otherwise be open to ensure that the excess fuel goes down the exhaust to the catalytic converter rather than get recycled through the combustion chamber, so blocking the EGR valve doesn't impact on a DPF regen at all.
Post #576641 19th Dec 2020 9:15pm
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Hi NorthernMonkeyJones,
Did you ever get to the bottom of this old issue from a few years ago? I have exactly as you described and want to resolve it.
Did you, or anyone, update the PCW and did it actually fix that issue? I have a remap and an update would remove that so would incur more cost if I want to re remap the car… and want to avoid that if it doesn’t fix the issue. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #661799 13th Apr 2023 7:42pm
Ffrr-lover
Before anyone else says it…
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #661800 13th Apr 2023 7:43pm
KristoffL322
United Kingdom 2012 Range Rover Westminster 4.4 V8 Orkney Grey
Mine does it as well, I took a short video of it. Sounds like turbo flutter or turbo chatter to me. Back in the day when I used to modify cars this is the noise my turbos made if I didn’t run a dump valve. Air goes the wrong way past the spinning fan blades when you lift off the throttle and makes that noise. It got worse when I upped the boost with a remap.
However.....having done some research on it and asked my local Range Rover indy, they tell me it’s the secondary turbo inlet isolation valve and its nothing to worry about. Not sure, but thats what they tell me.
https://www.youtube.com/shorts/3rn-lsmbw8M 2012 4.4 TDV8 Westminster
Post #662017 16th Apr 2023 11:44am
Ffrr-lover
It hasn’t always done that so something has changed or isn’t operating as it should. While it may not be a problem, surely it’s having an adverse effect.
In my case (and in the very first post by northernmonkeyjones) there is a loss of power as the secondary turbo comes into play. My previous post wasn’t clear, but that’s my biggest frustration which I was wondering if it’s been resolved?
However I’m sure the two are related… Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #662020 16th Apr 2023 12:52pm
Page 3 of 4 <1234>
