Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4310 |
Gaskets and O rings needed me thinks. No huge leak but needs doing....
29th Sep 2018 7:07pm |
Makes sense now Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
29th Sep 2018 8:49pm |
Masterblaster Member Since: 02 Jan 2017 Location: Essex Posts: 2 |
Further to the oil issues. LR has refused to cover this as just outside their warranty, and inchecape says that this is a manufacturers defect, so also will not touch it. LR quoted £1800 for the repair, Will have the local indi have a look next. The odd thing is following the tips earlier in the thread, I do not see oil from the cooler or the top union, I brought the o-rings mentioned to do it my self, but as its not from the top, i assume it must be from the Turbo end of the connection?
22nd Oct 2018 12:30pm |
Few good independent specialists around Essex. Do a search on here and sister forums
22nd Oct 2018 4:45pm |
Thanks Dr Rob, I have it booked in at Simply serviced in Stanway, I have had all other work done there. Will be interesting to see if they come back with the same issue. LR are quoting Turbo drain mod as the issue, yet I've not seen leaks from this as topic on the forum. Will keep you posted incase I've come across a new issue. |
23rd Oct 2018 1:26pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3783 |
Several 4.4tdv8 owners have had low down oil leak problems from the oil drain tube connection after it has been disturbed by being used to drain the engine oil rather than sucking it out from the top.
23rd Oct 2018 1:57pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 |
+1 for a lower, as yet unidentified oil leak
23rd Oct 2018 2:28pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8662 |
I had a leak around the NS turbo.
23rd Oct 2018 3:36pm |
Could you remember or find any more details NMJ?
24th Oct 2018 1:11am |
scuddriver Member Since: 12 Feb 2015 Location: Dunbar Posts: 140 |
I replaced the two O rings on the feed pipe to the oil cooler some time ago, but still had a leak, so I took it to my local Indy (Whites in Edinburgh) who replaced both oil cooler gaskets. They took 3.7 manhours and charged £300 including VAT. This might be a useful benchmark price for others who have the same problem, and I guess it is a whole lot less than a stealer would charge. 2011 Vogue TDV8 4.4
15th Nov 2018 5:18pm |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 502 |
I noticed some oil on the engine tray back in Oct post a service, cleaned it up and assumed it was from changing engine oil or similar.
29th Dec 2018 8:46pm |
ref: https://www.fullfatrr.com/forum/topic35830...t=oil+leak
29th Dec 2018 9:03pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2538 |
The main drain is by unclipping a hose and the secondary being a plug further back.
29th Dec 2018 9:25pm |
thank you Graeme, Main drain and 2ndary being bottom of sump and quite self explanatory when tray if off i take it? Cheers
29th Dec 2018 9:34pm |
