Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix
Page 19 of 38 <123 ... 181920 ... 363738>
DrRob
Gaskets and O rings needed me thinks. No huge leak but needs doing....
Are there 2 gaskets between cooler and engine?
 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #490353 29th Sep 2018 8:07pm
GraemeS
Australia
The oil cooler sits on top of the oil filter housing (gasket 1) then the oil filter housing sits on top of the EGR cooler (gasket 2). Remove the oil filter housing and oil cooler as a unit then disassemble.
Post #490370 29th Sep 2018 9:35pm
DrRob
Makes sense now Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #490377 29th Sep 2018 9:49pm
Masterblaster
Further to the oil issues. LR has refused to cover this as just outside their warranty, and inchecape says that this is a manufacturers defect, so also will not touch it. LR quoted £1800 for the repair, Will have the local indi have a look next. The odd thing is following the tips earlier in the thread, I do not see oil from the cooler or the top union, I brought the o-rings mentioned to do it my self, but as its not from the top, i assume it must be from the Turbo end of the connection?
Not visible from underneath without major stripping. Any advice on this one.
Thanks Chris
Post #493242 22nd Oct 2018 1:30pm
DrRob
Few good independent specialists around Essex. Do a search on here and sister forums Thumbs Up
For example: http://www.fullfatrr.com/forum/topic10508.html?highlight=essex Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #493274 22nd Oct 2018 5:45pm
Masterblaster
Thanks Dr Rob, I have it booked in at Simply serviced in Stanway, I have had all other work done there. Will be interesting to see if they come back with the same issue. LR are quoting Turbo drain mod as the issue, yet I've not seen leaks from this as topic on the forum. Will keep you posted incase I've come across a new issue.
Post #493361 23rd Oct 2018 2:26pm
Baltic Blue
Several 4.4tdv8 owners have had low down oil leak problems from the oil drain tube connection after it has been disturbed by being used to drain the engine oil rather than sucking it out from the top.
It might be worth a look.
Mike
 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #493363 23rd Oct 2018 2:57pm
GGDR
+1 for a lower, as yet unidentified oil leak
Mine:
~ has not had the turbo drain
~ has had the oil cooler done
~ has had the upper rear o-rings done
My leak is around the NS turbo area.
Let us know what the Indy says!
. Cheers, Greg
Post #493364 23rd Oct 2018 3:28pm
I had a leak around the NS turbo.
Dealer fixed under warranty a couple of years back. I think it was leaking from the oil feed Banjo (if there is one....), it a while back so its a hazy recollection. There is nothing that can't be fixed with a hammer😜😜
Post #493368 23rd Oct 2018 4:36pm
GGDR
Could you remember or find any more details NMJ?
. Cheers, Greg
Post #493423 24th Oct 2018 2:11am
scuddriver
United Kingdom 2011 Range Rover Vogue 4.4 V8 Java Black
TDV8 4.4 Oil Leak
I replaced the two O rings on the feed pipe to the oil cooler some time ago, but still had a leak, so I took it to my local Indy (Whites in Edinburgh) who replaced both oil cooler gaskets. They took 3.7 manhours and charged £300 including VAT. This might be a useful benchmark price for others who have the same problem, and I guess it is a whole lot less than a stealer would charge. 2011 Vogue TDV8 4.4
1992 Mazda Mx5
Post #495662 15th Nov 2018 6:18pm
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
I noticed some oil on the engine tray back in Oct post a service, cleaned it up and assumed it was from changing engine oil or similar.
then totally forgot about it and we have a gravel driveway so havent seen any marks.
Anyway, misses came home today and said Engine oil low message had come up. Had a look and the engine bash tray underneath is covered in dripping engine oil, seems the whole tray. service was approx 1k miles ago. Anyway will pull the tray off tomorrow and have a look.
from this post, which took me a while to read the 19 pages, it seems these leaks relate to the oil coming down the back of the engine, where as mine i would suggest is from the front and running on the tray to the back. Car is parked very slightly nose up.
Plan is to remove tray and check drain plugs to start, i believe there are two? is that correct? then see if oil path can be traced back to find leak. if coming from top i will take a look at the cooler and the filter itself.
Note comments on the filter housing being plastic. its it possible its split on retightening and causing this? Cheers
James
Post #500018 29th Dec 2018 9:46pm
JST
ref: https://www.fullfatrr.com/forum/topic35830...t=oil+leak
and the 2nd pic on first post. my oil leak is not quite as bad, but is further forward, the only bit on the exhause pipe is what has come off the underbody tray and blown back rather than dripped down onto it. Cheers
James
Post #500020 29th Dec 2018 10:03pm
GraemeS
Australia
The main drain is by unclipping a hose and the secondary being a plug further back.
The filter cover is plastic and is fitted with an o-ring. The cover might not be properly tightened.
Post #500023 29th Dec 2018 10:25pm
JST
thank you Graeme, Main drain and 2ndary being bottom of sump and quite self explanatory when tray if off i take it? Cheers
James
Post #500024 29th Dec 2018 10:34pm
