Home > In Car Electronics (L322) > upgrade to DAB+
Page 2 of 8 <12345678>
chief64
Norway 2010 Range Rover Autobiography TDV8 Buckingham Blue
On the lowest picture,right side, upper part, you see the coax cabel and antenna, there instal amp for antenna.
Left side, some place close to the floor, you should find the coax that should be conected to the DAB unit, then conect the MOST cabel and powersupply.
Post #428526 20th Feb 2017 5:07pm
nino_nino
thank you chief64, do you have link to the place you ordered from?
Post #428571 20th Feb 2017 9:26pm
chief64
dab+
http://www.jaguarforums.com/forum/xj-x351-...js=1#links
link to jaguar forum with a good description of DAB system
Post #428637 21st Feb 2017 1:31pm
nino_nino
Post #428650 21st Feb 2017 3:20pm
It's ashame the 06-09MY can't be upgraded so easily Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #428654 21st Feb 2017 4:22pm
theres no need to upgrade to dab+ Will..
the UK will stay on normal dab for the foreseeable future and theres only three or four local stations in the UK that broadcast in dab+ ... - .- -.
Post #428662 21st Feb 2017 4:59pm
I don't even have DAN stab Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #428663 21st Feb 2017 5:16pm
of course you dont, sorry didnt notice... Wink
your auto correct gone wrong again.... Laughing ... - .- -.
Post #428665 21st Feb 2017 5:26pm
Ha ha yeah sodding thing! I woulld sort it out but it adds more fun to the day and anywhere I post to lol FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #428666 21st Feb 2017 5:41pm
capcgn
Germany 2006 Range Rover Westminster 4.4 V8 Chawton White
I like to swap from DAB to DAB+ to
I have a 2012 TDV8 Autobiography with RSE and DAB Radio. I like to swap to DAB+. What parts do I need ? Only the DAB+ unit and the small green connector Cable ? Or do I need more ? Where exaxtly is the DAB unit located ? Can you send a picture ? Do I need to go to LR to code the DAB+unit ? Thank you
Andreas
Post #446511 3rd Aug 2017 1:01pm
dirtymonkey38
Anyone know what is above the green unit (DAB antenna/amplifier) in the picture? Mines wrapped in gaffer tape and I'm curious.
 2011 RR Autobiography 4.4 TDV8
Post #481633 22nd Jun 2018 7:35pm
S.Hafsmo
Norway 2007 Range Rover Vogue TDV8 Orkney Grey
What aerial does the later L322s use for DAB? Is it one of the side windows?
Post #491525 9th Oct 2018 5:50am
yes, side window antennas i believe..
Post #491559 9th Oct 2018 11:27am
S.Hafsmo
Can one assume these would be different than the older FM-aerial windows? Or possible to retrofit?
Post #491560 9th Oct 2018 11:29am
they would be the same for FM and DAB......
Post #491561 9th Oct 2018 11:32am
