![]() | Home > Technical (L322) > Egr delete... |
Spooky Member Since: 03 Aug 2009 Location: Swindon, Wilts Posts: 190 ![]() ![]() ![]() |
Hmmm ... interesting topic!
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
my remap was 5 years ago by cam-tech and egrs weren't touched so were still in use and by looking at it in less than twelve months were quite mucky and dirty as both turbos and egrs and the pipes were brand new last September and three oil changes since so imo a job well done. _____________________________________________________
ptaroni Member Since: 20 Dec 2015 Location: leicestershire Posts: 89 ![]() ![]() ![]() |
No mapping has been carried out on mine.... yet! 2004 td6 l322 - gone
gilesharrison Member Since: 04 Aug 2018 Location: Cumbria Posts: 163 ![]() ![]() ![]() |
I'm interested in doing this. My 3.6 TDV8 has fully functioning EGRs at present.
Hmmm ... so the re-map pretty much mapped them out? That'll explain the lack of warning lights, then ... Regards,
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
I reckon these pics hint at the benefits of no EGRs. Different vehicles, similar mid 200,000 km. One had operational EGRs the clean one (mine) not.
Vogue tdv8 08MY poverty pack - wow |
Benner91 Member Since: 18 Oct 2015 Location: Belfast Posts: 87 ![]() ![]() ![]() |
Hi all I have now decided to blank out my egr valves I have ordered the kit off eBay
Photos of brackets |
Remove the rear pollen housing box by the 13mm nut either side of the bulkhead then lift out to get at the rear harness bolts then loads easier to lift out the way, I’m doing another one for a friend tomorrow. _____________________________________________________
Took your advice removed pollen filter Couldn’t believe how easy it was to disassemble and remove egr hoses Blanking kit arriving tomorrow morning can’t to fit it and go for a drive I’ll keep you informed how it drives and mpg Thanks |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 474 ![]() ![]() ![]() |
Perhaps a silly question but presumably this is also applicable to the 2010MY with the 3.6 engine? 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
Yes same engine—after a lot of research I thought it would be the best option for me car has 130000 miles didn’t want to spend all the money replacing them when I could blank them off — heard to many horror stories of egr valves falling and getting sucked up into the turbos and ruining an engine
Egr delete kit arrived this morning from eBay
mrtidy Member Since: 31 Aug 2015 Location: Stockport Posts: 214 ![]() ![]() ![]() |
How easy is the kit to fit benner?i replaced both my egr valves about 6 months ago so might consider doing this too.just a bit concerned about the check engine light coming on. 2009 Vogue SE Zermatt silver |
