Home > Technical (L322) > Egr delete...
Page 5 of 7 <1234567>
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
IMO, if you blank off the egr's then have them mapped out. That way the correct flow data is received by the ecu.
But if you are gonna map them out it makes sense to go for a better fuel map too. The 3.6 TDV8 is in a low state of tune as standard and responds well to a remap. Nowhere near it's design limits as suggested . The gearbox however is near to it's stated torque limit.
That said, it can handle a remap well enough as its driven through a torque convertor and not directly.
I've had no problems at all only the benefit of cleaner oil, a smoother engine that pulls like a train and is oh so quiet. Mpg is up by around 2-3.
As for the MOT, yes, it's a fail. However with engine cover on it can't be seen.
You don't actually need to blank the egr's off. Just map them out, but they can still break up and lunch the turbo's .
So the choice is yours. I don't regret doing it and it's been the first thing I do on any diesel engine I've owned.
Your engine will thank you 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #507555 5th Mar 2019 11:19pm
drakes
If people are worried about blanking EGR and an MOT tester seeing it could you not just "sandwich" the blanking plate at the one end of the pipe eith the pipe still in position so it appears normal. I have done this in the past on non LR vehicles. This way even if an MOT tester was trying to have a sneaky look under the engine cover it would be almost impossible to spot 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
Post #507945 8th Mar 2019 10:55am
RichM63
France 2006 Range Rover Vogue TDV8 Stornoway Grey
EGR Delete longevity
Having read this thread and any and all others that I could find on the subject of EGR blanking on the 3.6 TDV8 I've gone ahead and ordered the EGR Delete kit as per others.
2 points; some of you have done this modification and run for 12 months or so. Question without a remap/delete is everything still OK or is a remap really required?
Second point, does anyone know of where I can get a remap from anywhere near me in Brittany, or is there a hidden Quantum or other agent lurking about.
FFRR are as rare as Hen's Teeth around here, my Insurer had to get authorization from head office just to identify the thing correctly. Thus non existent indi' support.
Cheers,
Rich
Post #522312 20th Jul 2019 6:17pm
Weegie
You could consider https://bellautoservices.co.uk who do remote remaps. It would mean having also to purchase a Gap iiD (if you don't already have one) but that would be a very useful item to have, unless your relatives have suitable diagnostic already.
Just a thought for you. BAS are highly thought of by members on here. John
GAP iiD BT
Post #522314 20th Jul 2019 6:35pm
Benner91
United Kingdom 2007 Range Rover SE TDV8 Java Black
I didn’t remap just fitted the kit I have driven 15000 miles now with egr s blanked fuel consumption up a couple of miles to the gallon better throttle response
Glad I did it 👍
Post #522315 20th Jul 2019 6:35pm
rar110
The EGRs on my 3.6 have been disabled for 3 or 4 years now. No I’ll effects. The motor was immediately a little smoother at idle without the EGRs. Not a big change but noticeable.
I went a different way and bought emulators. The emulators allow the EGRs to be unplugged and so sit idle in the closed position. The longer term plan is to remove the EGRs and related cooling hoses completely.
But try a blanking kit. It’s a very cheap way to go and you probably won’t need a remap. ______________________________
Post #522336 20th Jul 2019 8:37pm
ur20v
A Trap
Deleted
Post #522365 21st Jul 2019 8:42am
RichM63
Thanks for the feedback folks. Reassuring to know, especially as my nearest remap is a boat trip away. Thumbs Up
Post #522366 21st Jul 2019 8:48am
RichM63
Well we did the 'delete' yesterday afternoon, under an hour all told.
First impression today, cold start idle immediately solid and not all over the place.
Gentle driving, 50mph, revs settled and not randomly hunting around 15/17k rpm. they were, up, down, up, down,.......
Car up to temp, and feels more responsive, also showing 28mpg on both readouts, pootling around country lanes from zero to sixty mph.
We'll see how this pans out, but the car just seems to say "thank you, I can breathe". Smile
Best, Rich
Post #524170 8th Aug 2019 6:33pm
ur20v
A Trap
Deleted
Post #524228 9th Aug 2019 11:34am
RichM63
LOL Ha Ha Rolling with laughter
Post #524261 9th Aug 2019 2:08pm
Weegie
Am I correct in thinking that if you use the blanking kit you still leave the EGR electrics plugged in? John
GAP iiD BT
Post #524377 10th Aug 2019 12:55pm
MarianaWestminster
I have fitted the egr-delete ebay kit to my 2010 facelift 3.6 autobiography today and I echo the comments made by other posters. Big improvement however I already knew what it would be like having had an electronic delete on a previous TDV8.
No eml as yet.
Post #524391 10th Aug 2019 3:42pm
Red Merle
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
EGR’s in place, all working fine at 60,000+ miles, no MoT issues, happy to keep those NOx emissions in check and keep those eBayer’s that sell this kit as poor as possible! Very Happy Thumbs Up
Post #524392 10th Aug 2019 4:00pm
Weegie
Anyone? John
GAP iiD BT
Post #524394 10th Aug 2019 4:29pm
