Home > Technical (L322) > Egr delete...
Page 6 of 7 <1234567>
kbald
The instructions I have don't say anything about disconnecting so they should be connected.if you disconnect that will throw up error messages. Current 2007 TDV8 Vogue Buckingham Blue
Post #524397 10th Aug 2019 4:44pm
Weegie
Thumbs Up John
GAP iiD BT
Post #524399 10th Aug 2019 4:44pm
RichM63
France 2006 Range Rover Vogue TDV8 Stornoway Grey
Weegie wrote:
Weegie wrote:
Am I correct in thinking that if you use the blanking kit you still leave the EGR electrics plugged in?
Anyone?
Correct. Leave all wiring connected.
Best..
Post #524400 10th Aug 2019 4:47pm
Weegie
Thanks to both. Very Happy John
GAP iiD BT
Post #524401 10th Aug 2019 4:58pm
Red Merle
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
A little background reading on NOx:
https://www.google.co.uk/amp/s/phys.org/ne...-fumes.amp
Post #524404 10th Aug 2019 7:38pm
rar110
If you unplug the EGR, the ECU will identify it and you will get a fault. So either leave it plugged in or plug in emulators instead of the EGRs. ______________________________
Post #524577 12th Aug 2019 8:37pm
Brian S
My 2007 model has been playing up a bit and I don't know if the EGR is at fault.
Car has a remap from a previous owner and I don't think the EGR's were deleted. The reason is that before the last service the EML light would come on and the code was for the Gas re-circulation valves, so the indy I use suggested he fill the fuel filter with fuel additive when he changed it to clean the system. It worked and ive not had the light come back on.
The last few months though, when the car is warm it sometimes hunts when accelerating, often up a hill. Now a google search suggests the torque converter but i'm not convinced, especially with the past history of my egr's.
My question is, if it is the EGR's on the way out would the blanking kit fix the issue or would i need to have them mapped out as well?
Post #524594 13th Aug 2019 9:08am
ur20v
A Trap
Deleted
Post #524609 13th Aug 2019 12:31pm
Brian S
Well i've just ordered a set off ebay so ill report back my results.
Post #524610 13th Aug 2019 12:45pm
ur20v
A Trap
Deleted .
Post #524647 13th Aug 2019 4:09pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
https://0www.google.co.uk/amp/s/phys.org/n...-fumes.amp
Having read the article it appears to be all true to a point. However, there is no mention of Dpf's capturing the danderous particles and the fact that Nox gasses are unstable and dissipate within 20 mins. The Egr system is fundamentally flawed in that it destroys engines slowly by choking them up causing rough running that increase emissions and eventually self distruction. There are much better ways to control Nox emissions.
It is simply a case of reducing the temerature of combustion. Water injection was used in 2nd world war, Ffs.
I have personally tested equipment easily retro fitted to any car or truck that has reduced all emissions to virtually zero.
That was after removing the DPF and egr. MOT tester's were, in their own words, astounded but couldn't give me an MOT as it didnt meet regulations. Farcical is the only term for the gov's handling of the issue.
The policies are about increasing revenue. Its that simple. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #524775 14th Aug 2019 12:51pm
ur20v
A Trap
Deleted
Post #524801 14th Aug 2019 3:09pm
Grofus
Yeah, i hadn't considered the lack of CO2 for plants and trees, but you are right. Really Censored annoys me, all this crap.
P.L.L mate
Edit: Further to that is the fact that we all have a fundamental constitutional right to travel. The gov. removes that and replaces it with a privilege called driving. Then screws us over for us daring to do so.
I could go on about the legal fiction, juristic person etc. but won't for the sake of my sanity. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #524815 14th Aug 2019 3:43pm
Brian Considine
In general, I agree with most of what Grofus & ur20v say.
If NOx dissipates after a short time then surely, in the case of HGV's it would be better if they ALL had exhaust stacks so it can do no damage whilst it is harmful ?
Many large fleets have trialled LPG & it's variants and results are varied.
I have yet to meet an experienced diesel engineer who has a good word to say for DPF's and the associated emissions equipment.
Those that think regeneration is a good idea need to experience an HGV that has gone into regeneration - increased idling speed (using fuel) smoke you would not believe, a disgusting smell and dire health warnings (in the handbook) to make sure the vehicle is in the open and you keep at least 2m away from it until it returns to normal !
Just how this can be good for peoples health and the environment is beyond me.
I won't comment on AdBlu (well, not at the moment anyway).
Lets face it, if the people that design & research diesel engines had been allowed to "get on with it" without the tree huggers interference we would have diesel engines that would be far, far more efficient that the present ones in terms of fuel consumption.
In any case, natural replacement (especially with the bigger fleets - of all vehicle sizes) means that the percentage of "cleaner" vehicles will rise meaning that the "knee-jerk must get older diesels off the road" reactions are largely unnecessary.
BTW - most Euro VI HGV's are all auto's these days - manuals are (if even available) special order.
Here's a thought - Next time you see a temperature controlled Class I HGV with a Euro VI engine in the prim mover ask yourself about the diesel engine powering the temperature control equipment ? 2003 Range Rover Vogue TD6
Post #524816 14th Aug 2019 3:47pm
Andy
I was messaging the owner of Alive Tuning two weeks ago and he said I should refit the EGRs? Mine is already remapped including digital EGR deleted but I didn’t know about this until longer after I’d bought the car, by which time I’d mechanically deleted the EGRs.
I don’t think it’s a great map as it runs nice and quiet to start with but then gets noisy as it’s warming up. I get anything from 12 to 26 mpg on the exact same runs every day so it’s all over the place. It sounds like a transit when accelerating so Alive suggested putting it back to standard to see how it runs then. BAS had a look at the map via IID tool and said it was a “reasonably well done” map and said I didn’t need theirs which was honest of them. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #527125 5th Sep 2019 8:31am
