Home > Technical (L322) > Egr delete... |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 |
Isn't an egr delete an MOT fail nowadays? Bish.
21st Sep 2018 4:52pm |
Benner91 Member Since: 17 Oct 2015 Location: Belfast Posts: 87 |
It is not an mot failure I reaserched this before
21st Sep 2018 6:41pm |
kgeddes Member Since: 11 Jan 2015 Location: UK Posts: 289 |
Not an mot failure, mine has egrs deleted, had it tested yesterday...passed with no issues |
21st Sep 2018 6:46pm |
gj88 Member Since: 10 Sep 2018 Location: West Midlands Posts: 213 |
I'm pretty sure it is an MOT fail. They're unlikely to spot it as they won't take the engine cover off, but if they're aware, I'm confident it's a fail |
21st Sep 2018 6:48pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
Well done.
21st Sep 2018 8:40pm |
BigJon Member Since: 05 Apr 2013 Location: Adelaide - Lower Mitcham Posts: 14 |
I have been running emulators for over a year now. About a month ago I had an EGR cooler failure, pushing coolant straight out the exhaust system. Spectacular clouds of coolant steam that would have done James Bond proud. I now have no EGRs or coolers at all. I suspect I need to refit the thermostats from the coolers into the hose joiners I made as it runs a bit cooler than it used to. Other than that, no issues. |
22nd Sep 2018 12:42am |
Good one Jon.
22nd Sep 2018 2:32am |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 518 |
My tips for fitting the kit in case they're any use to anyone
22nd Sep 2018 8:14am |
I would think so. |
11th Nov 2018 1:56am |
I might have to get my EGRs removed. ______________________________
11th Nov 2018 2:34am |
I was told it is a very uncommon failure for the coolers to split. Guess I am just lucky! |
11th Nov 2018 2:44am |
Henda Member Since: 02 Aug 2018 Location: Gateshead Posts: 282 |
Well after reading these posts I have ordered the blanking kit and weather dependent I will fit on Wednesday or Thursday and take photos hopefully
12th Nov 2018 9:37am |
Which one did you go for Henda? Thinking about doing the same next weekend |
12th Nov 2018 9:51am |
The same ones as posted on this thread £34.89 posted
12th Nov 2018 10:31am |
