Home > Technical (L322) > Egr delete...
Page 2 of 7 <1234567>
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
Egr delete done and not to hard tbh,make sure you take the pollen filter housing off though so you can get to the harness bracket rear bolts.Pipes were new last year with new egr valves and when checked quite oily and sootey so not good going back into the engine imo and now response is better and happy after a good run no engine issues or lights so worth doing Thumbs Up
 _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #488954 15th Sep 2018 12:32pm
Spooky
United Kingdom 2014 Range Rover Autobiography 5.0 SC V8 Corris Grey
Hmmm ... interesting topic!
Can anyone confirm (or otherwise) whether the engines in question had had the EGRs mapped out, or whether they were in all other respects standard??? Regards,
Mick
'Bertha' - 2014 SDV8 Autobigraphy
'Vincent' - 2010 TdV8 Vogue SE
- 'Molly' - 2005 HSE Auto
'Dixie' - 2000 D2 Td5 ES
Post #488959 15th Sep 2018 2:01pm
Scottyav
my remap was 5 years ago by cam-tech and egrs weren't touched so were still in use and by looking at it in less than twelve months were quite mucky and dirty as both turbos and egrs and the pipes were brand new last September and three oil changes since so imo a job well done. _____________________________________________________
Post #488960 15th Sep 2018 2:10pm
ptaroni
No mapping has been carried out on mine.... yet! 2004 td6 l322 - gone
Now 2007 tdv8 l322
Post #489174 17th Sep 2018 9:18pm
gilesharrison
United Kingdom 2008 Range Rover Vogue TDV8 Stornoway Grey
I'm interested in doing this. My 3.6 TDV8 has fully functioning EGRs at present.
My worry is this. By blanking off the pipework but leaving the EGR valves in place, they will open and close as required so no EML or errors will arise, at first. However, I imagine over time, as there will be no 'flow' through the EGR valves, they will clog and fail. If the remap is done to stop them opening at all, this obviously wouldn't happen.
Any thoughts?
Post #489183 17th Sep 2018 10:26pm
Spooky
Hmmm ... so the re-map pretty much mapped them out? That'll explain the lack of warning lights, then ... Regards,
Mick
Post #489188 18th Sep 2018 5:09am
rar110
I reckon these pics hint at the benefits of no EGRs. Different vehicles, similar mid 200,000 km. One had operational EGRs the clean one (mine) not.
Post #489195 18th Sep 2018 8:50am
Benner91
United Kingdom 2007 Range Rover SE TDV8 Java Black
Egr blank
Hi all I have now decided to blank out my egr valves I have ordered the kit off eBay
My only issue is access there is a black cover which seems to be removed to access all bolts to remove egr bend
How is this removed and how many bolts is there - there is one cover on each side
I have included a photo we’re the cover goes from the eBay listing
Thanks in advance
Post #489391 20th Sep 2018 10:56am
Benner91
Photos of brackets
Post #489396 20th Sep 2018 11:31am
Scottyav
Remove the rear pollen housing box by the 13mm nut either side of the bulkhead then lift out to get at the rear harness bolts then loads easier to lift out the way, I’m doing another one for a friend tomorrow. _____________________________________________________
Post #489418 20th Sep 2018 3:33pm
Benner91
Thanks Scott
Took your advice removed pollen filter
Couldn’t believe how easy it was to disassemble and remove egr hoses
Blanking kit arriving tomorrow morning can’t to fit it and go for a drive
I’ll keep you informed how it drives and mpg
Thanks
Post #489422 20th Sep 2018 5:02pm
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
Perhaps a silly question but presumably this is also applicable to the 2010MY with the 3.6 engine? 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
2009 3.6 V8 (MY2010) - my first ever diesel! - now also gone Sad
2004 4.4 V8 Petrol Vogue - now gone
Post #489423 20th Sep 2018 5:15pm
Benner91
Yes same engine
Yes same engine—after a lot of research I thought it would be the best option for me car has 130000 miles didn’t want to spend all the money replacing them when I could blank them off — heard to many horror stories of egr valves falling and getting sucked up into the turbos and ruining an engine
My car was a bit rough in the morning until warm a bit of smoke until I reved it a bit and the fault was egr b control circuit low it never put eml light on
Just new it wasn’t running correctly for first 20 seconds after cold start
Hopefully when kit arrives tomorrow and is fitted all will be good
Post #489424 20th Sep 2018 5:29pm
Benner91
Update on my delete kit
Egr delete kit arrived this morning from eBay
Kit was easy to install all came with detailed instructions
It’s like driving a different car first thing I noticed was the Rev counter from cold start was rock solid (previous hunting on cold start until engine had warmed a bit )
Engine considerably quieter
I drove 100 miles — from a standing start she is a lot quicker more responsive
Also when driving and I put the boot down she flys reduced turbo lag before there was a split second then she would go
Over all I am pleased to the moon also no engine warming light has displayed if this is a problem in the future then I will get the egr software removed
I have now reset the mpg so I can see if it will increase
I think all 3.6 owners should consider this modification to protect there turbo
Thanks
Post #489465 21st Sep 2018 12:07pm
mrtidy
United Kingdom 2009 Range Rover Vogue SE TDV8 Zermatt Silver
How easy is the kit to fit benner?i replaced both my egr valves about 6 months ago so might consider doing this too.just a bit concerned about the check engine light coming on. 2009 Vogue SE Zermatt silver
Post #489471 21st Sep 2018 2:09pm
