Home > Off Topic > "G4 Black" Land Rover D3 Project
Page 7 of 15 <123 ... 678 ... 131415>
Paulo
Thanks Gaz & Scarey... Thumbs Up
Top blokes, more beer tokens to be spent this week.... Laughing
Post #47825 27th Jan 2011 3:28pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
looking good. agree with scary, blue tacked stickers look fine, no more... Wink
really like them wheels 2004 black Vogue TD6
Post #47842 27th Jan 2011 4:32pm
OK then any bright ideas for attaching these to front end:
Post #47847 27th Jan 2011 5:10pm
Fox
Don't they do a light mounting bar that sticks out through the front grille?
Edit:
Yep, Driving Light Mounting Brackets.
Discovery 4 accessory brochure, page 50. Thumbs Up
Or Disco 3 here:
http://accessories.landrover.com/inter/acc...3AF528894A
Post #47886 27th Jan 2011 8:47pm
Thanks Fox,
I was aware you can mount to Bumper having had LR driving lights fitted on my Discovery 3 Metropolis LE but I am after a different look with the lights bolted to a raised bar or similar...(hard to describe)
I guess I have no choice but to go down the traditional route though Thumbs Up
Post #47907 27th Jan 2011 10:42pm
Fox
I think I know what you mean.
There is an aftermarket bar for the Defender, that pokes out through the grille and you can mount a pair of spots on that.
But I've not seen anything similar yet for the Disco 3/4.
Something liek this:
http://www.devon4x4.com/index.php?page=sho...;Itemid=14
Post #47910 27th Jan 2011 11:01pm
Yes it was defender style Spot lights that I was after Thumbs Up
Just had a look and the D3 Bumper appears to be strengthened on the underside and looks as if you could drill directly through it to attach Hella/Wipac 8" Defender style side by side driving lamps with a a bit of plate on either side......
PS Apparently the LR Spot Light attachment kit works with other Lamp Models so I will go down this route and fit 8" side by side lamps.
Last edited by Gazellio @ Prestige Cars on 2nd Feb 2011 10:31pm. Edited 1 time in total
Post #47919 28th Jan 2011 7:33am
I fitted the front lamp guards today (Britpart) and was surprised at how easy it is to dismantle Land Rover parts if you have good instructions and the right tools.
Within Minutes I had the front grill removed quickly followed by both Headlamp Units after using WD40 on the sliders and disconnecting the wiring looms.
Next you have to insert plastic grommets that take the screw bolts holding the guard brackets intp pre-formed square holes in the bonnet frame and this proved to be the most difficult job as the plastic was cold and hard and the pre-formed holes where filled with paint and basically too small for the grommets!
After a little filing of the grommets and clearing of the excess paint I had them in and was able to reassemble the light units and grill and bolt on the guards within minutes.
All told about 25 minutes to do both sides and the look was very aggressive especially as the black guards match the black car.
Tomorrow I will fit the rear lamp guards (this involves drilling into bodywork) and will post a few pictures of the front & back end result Thumbs Up
Post #48545 2nd Feb 2011 10:27pm
letsavit2
little bit of zinc primer on them body holes gav...
More pictures soon? 2004 black Vogue TD6
Post #48705 3rd Feb 2011 10:41pm
Gav - oooh er I am going all welsh my lovelies Laughing
Yes I will treat them there holes and silicone them as well..... Thumbs Up
Pictures soon....
Post #48706 3rd Feb 2011 10:44pm
letsavit2
Laughing 2004 black Vogue TD6
Post #48708 3rd Feb 2011 10:54pm
UPDATE
Yesterday & today I have added Front & Rear light Guards and a G4 LR Ladder:
Next:
Front Driving Lamp Kit
8" Driving Lamps
OEM RAI
soon:
Winch & Kit
Raised Coil Springs
Post #48800 4th Feb 2011 4:10pm
letsavit2
raised with a winch and she'll be looking the part.... Thumbs Up 2004 black Vogue TD6
Post #48875 4th Feb 2011 9:57pm
Don't forget the Raised Air Intake..... Cool
Post #48876 4th Feb 2011 9:59pm
letsavit2
rrrrr yes, a must... Wink 2004 black Vogue TD6
Post #48878 4th Feb 2011 10:03pm
