Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix
Page 18 of 38 <123 ... 171819 ... 363738>
SinbadRose
All done, wiped clean and seems to be sorted as it was covered in oil. Can't see anything else. Excellent info and pics from all. Thank you . Thumbs Up
Post #478805 18th May 2018 5:47pm
GraemeS
I've spotted a distinct difference between the pipes shown in diagrams/pictures and my April 12 build's pipe in that mine has a join between the flexible section and the rest of pipe that continues to the turbos. I can't currently loosen the bolt but once I have an appropriate tool, the end section of the pipe will be removed to allow the o-rings to be fitted whilst away from the back of the engine.
Post #482932 9th Jul 2018 6:30am
GraemeS
Some measurements from mine's later version 2-piece pipe:
Spigot dia 11.90mm - hole could well be BS611 spec of 12.0mm
O-ring groove dia 9.60mm - more than BS611 specs of 9.0mm
Old o-ring width 8.60mm. If anything, it would be wider than originally due to having been squashed.
New o-ring width 8.70mm - not quite BS611 specs of 8.78mm
Old o-ring on fitting 12.1mm
New o-ring on fitting 12.5mm
The seals provided good resistance when refitting with the new o-rings. I'm sure that BS611 is a good size but possibly has slightly greater section width than the original. The originals weren't hard, instead somewhat soft compared with the new Viton seals.
Post #483058 10th Jul 2018 2:40am
GGDR
where is that pipe from exactly Graeme?
. Cheers, Greg
Post #483061 10th Jul 2018 6:06am
GraemeS
Its at the top end of what was originally a single pipe. I suspect the 2-section pipe was developed so that it could be guaranteed that the fitting into the block could be under no stress. I rejoined mine after tightening the spigot in the block.
The picture posted early in this thread of the new pipe is still of the old pipe. I suspect that old stock was sold under the new part number because the join clearly is not shown in that picture.
Post #483069 10th Jul 2018 7:14am
RiDDO
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Fuji White
My 2012 TDV8 is currently at Duckworth's in Market Rasen having a new oil cooler, alternator & n/s rear light cluster. I've been smelling hot oil for almost a year, last Sunday afternoon smoke started coming from under the bonnet. Note to self in future check for this stuff on Full Fat! --RiDDO
Post #485467 8th Aug 2018 12:35pm
Ian S
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
Hi all I’ve just found oil leak on my tdv8 I’m going to check it tomorrow
Post #487790 1st Sep 2018 9:41pm
DrRob
"First, remove the air box that houses the pollen filter, 2x 13mm headed nuts then pull the whole assembly off. "
Anybody got a picture for clarity? Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #489301 19th Sep 2018 11:21am
Baltic Blue
Picture with airbox removed. (2x 13mm nuts to remove. 30second job.)
Mike.
 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #489302 19th Sep 2018 11:41am
DrRob
Cheers. I was after the location of the nuts - or is it pretty obvious Whistle Whistle Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #489303 19th Sep 2018 11:44am
Baltic Blue
Post #489313 19th Sep 2018 1:12pm
nino_nino
Thumbs Up 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #489314 19th Sep 2018 1:14pm
DrRob
Thanks. Helps heaps. Will be having a gander over next few days under there when I collect my 2011...
O rings purchased just in case... Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #489315 19th Sep 2018 1:14pm
Baltic Blue
Take a good look at this hose joint whilst you have the bonnet up.
Mine started to weep at the weekend.
Their is a very good cheap fix in a post on here somewhere, but sorry can’t just find it to link to at the moment.
Post #489316 19th Sep 2018 1:20pm
Frans@Yamorna
South Africa 2012 Range Rover Vogue SE TDV8 Zambezi Silver
That fitting failed on my car,fortunatly under MP.Nino_Nino has posted the fix and yes it is easy!! 2012 TDV8 Vogue SE 4.4
Post #489550 22nd Sep 2018 11:01am
