![]() | Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35513 ![]() ![]() |
i aint got it back yet so im not counting the proverbial chickens.. |
westie picked this pm and all seems ok.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
i now have some spare viton 'O' rings if anyone needs them... ... - .- -.
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1455 ![]() ![]() |
Those labour rates don't look that bad from a MD so can't have been that difficult or taken them that long..... My Westie warranty runs out in July so I'm going to start a really thorough check of everything over Easter to make sure I don't miss something which might be covered 2021 D350 Fifty Edition - Carpathian Grey 2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black 2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black |
@rambles...its all down to cost and if you can get to the other [lower] end of the pipe..
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 904 ![]() ![]() ![]() |
Interesting pricing that's been passed to the warranty company Stan.
the 'warranty' prices might be retail Mike.......dan seems to apply a discount for us members .. ... - .- -.
muppet Member Since: 09 Nov 2016 Location: manchester Posts: 90 ![]() ![]() ![]() |
Mine is still in the Dealers Stan with the same issue as you. I have had the cooler, the pipes etc changed but still the leaks.
let's hope that solves the problem Jeff...... |
roverron Member Since: 16 Apr 2009 Location: Londerzeel Posts: 86 ![]() ![]() ![]() |
I've the oil leak under the oilcooler.
Loosen the jubilee clips and slide the hoses as per arrows.
Thanks Mike
Thanks all the info above and help from this forum I was able to find the correct O-rings and fix the leak on the oil feed pipe early March.
