Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix
Page 16 of 38 <123 ... 151617 ... 363738>
i aint got it back yet so im not counting the proverbial chickens.. Neutral ... - .- -.
Post #473505 22nd Mar 2018 9:08pm
westie picked this pm and all seems ok.
this is for anyone who is curious how much the warranty peeps got charged,
oil filter [seal?] and cooler @ £244.38
oil feed pipe @ £ 97.95
brake cleaner [to clean excess oil?] @ £5.98
labour @ £ 309.00
all plus vat..
....and starter motor replacement,
starter motor @ £384.46
labour @ £116.05
again all plus vat. ... - .- -.
Post #473604 23rd Mar 2018 2:32pm
Baltic Blue
Thumbs Up Thumbs Up
Enjoy.
Post #473605 23rd Mar 2018 2:47pm
i now have some spare viton 'O' rings if anyone needs them... ... - .- -.
Post #473608 23rd Mar 2018 2:53pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Questions questions
Seems to be a suggestion that the oil supply pipe has been redesigned
Mk 1 to Mk 2
Is this right? So if I change to Viton rings I am being clever but really getting the new better Mk2 parts when the OE rings break down may supply oil better to my turbos ?
Do I need to change oil and coolant to do the job?
Is it a matter of time, and all will leak at some stage, so better as a preventative rather than remediation?
Same with gaskets on oil cooler?
Post #473786 25th Mar 2018 8:52am
Rob99
labour @ £ 309.00
all plus vat..
labour @ £116.05
again all plus vat.
Those labour rates don't look that bad from a MD so can't have been that difficult or taken them that long.....
My Westie warranty runs out in July so I'm going to start a really thorough check of everything over Easter to make sure I don't miss something which might be covered 2021 D350 Fifty Edition
2017 4.4 SDV8 Autobiography -
2012 4.4 TDV8 Westminster - Gone, but not forgotten
Post #473792 25th Mar 2018 9:42am
@rambles...its all down to cost and if you can get to the other [lower] end of the pipe..
@rob... good idea... i've booked my mot early may just before the warranty runs out so if anything needs doing it will be covered.. ... - .- -.
Post #473803 25th Mar 2018 10:57am
mpirie
Interesting pricing that's been passed to the warranty company Stan.
If memory serves, Ducky Dan was £100 cheaper for a starter motor, thought the oil cooler was about the same.
Mike
Post #473826 25th Mar 2018 3:27pm
the 'warranty' prices might be retail Mike.......dan seems to apply a discount for us members .. ... - .- -.
Post #473827 25th Mar 2018 3:32pm
muppet
United Kingdom 2012 Range Rover Westminster 4.4 V8 Barolo Black
Mine is still in the Dealers Stan with the same issue as you. I have had the cooler, the pipes etc changed but still the leaks.
They have just phoned me to say that it is a drainage pipe that is at fault and they are looking to see if they can get this done under warranty...will keep you all posted...
Jeff I need more help than most...sorry !!
Post #473889 26th Mar 2018 7:24am
let's hope that solves the problem Jeff......Thumbs Up ... - .- -.
Post #473891 26th Mar 2018 8:09am
roverron
Belgium 2012 Range Rover Autobiography TDV8 Ipanema Sand
I've the oil leak under the oilcooler.
How does one remove the airintake manifold on top of the 4.4 TDV8 engine as it is in between the 4 rubber hoses.
Do I have to take of one valve cover?
Thanks for the advice.
Ronald RR 2012MY TDV8 AB ipanema sand
RR 2004 TD6 sold now
Post #474905 5th Apr 2018 12:45pm
Baltic Blue
Loosen the jubilee clips and slide the hoses as per arrows.
Post #474907 5th Apr 2018 12:53pm
roverron
Thanks Mike
As simple as that Banging Head RR 2012MY TDV8 AB ipanema sand
Post #474928 5th Apr 2018 5:22pm
roverron
another oil leak
Thanks all the info above and help from this forum I was able to find the correct O-rings and fix the leak on the oil feed pipe early March.
But last week a new leak appeared, so I ordered the two gaskets for the oil cooler and changed them.
With no result as it is still leaking.
As in the V now all is dry, it must be coming from under the RH turbo, above the starter motor somewhere...
Both LR dealers near the place I live are fully booked for the 2 coming weeks ( why would that be?).
If I take out the starter motor, is there enough space to see the underside of the turbo above and have access to the oil feed pipe? Could someone confirm.
Thanks
Post #475349 10th Apr 2018 7:50am
