Home > Technical (L322) > 4.2 supercharged misfire on idle
Page 1 of 4 1234>
Dano0404
Hello, I’ve had my Range Rover for around a month now since owning it’s had a misfire on start up that would clear once warm. In the last week it seems to have got worse to always running lumpy on idle. The car has been converted to run on lpg and appears to be more noticeable on lpg, some times misfiring while driving. But I’m convinced this is related to the misfire on start up. I’ve had the throttle body off and it looked clean apart from a small amount of oil but I gave it a clean up. Changed the spark plugs cleaned the maf, replaced the pvc. When I had it plugged in it didn’t show a fault got my local mechanic to have a look but couldn’t see any thing and suggested a software up date from Land Rover. I asked him about running live values but said his machine doesn’t do that.
I’ve spent lots of time reading the internet at a bit of a dead end, thinking I may have to book it in to a more qualified garage.
I would be grateful for any advice and to keep me away from the steelers.
Thanks [/url]
Post #469635 21st Feb 2018 11:57pm
dingg1
what codes were showing ie which cylinder/s were misfiring?
if its just one cylinder try swapping coil packs and see if the problem moves with coil pack
Post #469636 22nd Feb 2018 12:04am
Dano0404
No codes relating to the misfire, I have had eml flashing at me a few times but just in lpg.
Post #469639 22nd Feb 2018 12:16am
dingg1
suspect your lpg system is not set up to optimum and needs a service/calibration
BUT if the original misfire is when on petrol when its cold further investigation will be required
how many miles has it done since conversion?
any valve saver system fitted?
any petrol addition selected to help combat potential of valve seat recession?
VSR can be an issue on these engines on poorly set up lpg systems.
ps even when a constant cel is not standing a simple elm327 with a phone app can show misfire codes
Post #469645 22nd Feb 2018 2:34am
Dano0404
Car has done around 20-30k on lpg. It had a flash lube system and I believe 10% petrol injection. I did think it could do with a lpg tune up but would be nice to get rid of the misfire on petrol first.
Car still drives on lpg and petrol drove fine last night just lumpy at idle.
It’s not throwing up any misfire codes on petrol only if left on lpg and then it’s on all cylinders.
Thanks
Post #469647 22nd Feb 2018 8:48am
400-ascona
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Java Black
Check for leaks on the flexi pipes from the LPG injectors to the inlet manifold. They tend to stiffen over time and don't seal as well. To be honest it normally smells of LPG too if they are leaking.
Post #469716 22nd Feb 2018 9:51pm
400-ascona
Did you manage to sort it?
Post #472975 17th Mar 2018 9:36pm
Dano0404
No not yet got the lpg serviced and been the same it always has.
Post #473147 19th Mar 2018 9:22pm
Dano0404
Plugged in to day and seems to be miss firing down one side more than the other. Did think about ordering a couple of coil packs and trying to change a few around.
 2007 sc
Post #513486 28th Apr 2019 5:21pm
friskydog
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
I am seeing very similar...
I have a 2007 SC L322 and just had a rebuild and I get a slight randomised shudder when im in the drivers seat consistently at idle. With these error codes...
I have had new engine rebuild, and new coolant hoses (all), engine and Supercharger water pumps, thermostat, new radiator, new chains-tensioners, MAF, PCV, spark plugs etc. Car runs ok but judders like I said at idle more so, but I believe the judder was there pre re-build and we never saw the following misfire codes.
Any ideas gents. Coil packs/injectors maybe? Any advice deeply appreciated I'm at my witts end after spending alot on the rebuild. Error codes materialised in the first 50 miles after a short stop.
 Range Rover Vogue SE 2007 L322 4.2 Supercharged 121k. Engine rebuilt @ 120666 Miles
Post #605432 2nd Sep 2021 7:10pm
dingg1
All bank one misfires, camshaft sensor?
Post #605435 2nd Sep 2021 7:36pm
friskydog
Would this be the part your refering to...
RANGE ROVER SPORT/L322 V8 CAMSHAFT POSITION SENSOR - LH
Produit de la marque: Land Rover Genuine
Reference: 4362957LR
Why would this particular part only create warnings on 1 bank? Is this something you've seen before?
Thanks for the thought I need all the help I can get here. Range Rover Vogue SE 2007 L322 4.2 Supercharged 121k. Engine rebuilt @ 120666 Miles
Post #605437 2nd Sep 2021 8:13pm
dingg1
Could be a possibility that the sensor is on its way out or the timing is slightly out on that bank after the rebuild. Try swapping sensors across banks if the problem moves to the other side you will have nailed it (thats if they are not lh and rh parts)
Post #605443 2nd Sep 2021 8:44pm
friskydog
Great I will check that thank you. Range Rover Vogue SE 2007 L322 4.2 Supercharged 121k. Engine rebuilt @ 120666 Miles
Post #605444 2nd Sep 2021 8:51pm
Sure I've read about this problem on USA Jaguar forums, they are the place to look at for the 4.2 and 5.0 supercharged engines as there are loads over there...
It was usually a fuel rail, there is one each side, or injectors, some have had to replace all the injectors and both fuel rails, others have had success with some BG 44k fuel injector cleaner...
Do some googling, you will find something... Thumbs Up Pete
Post #605449 2nd Sep 2021 9:44pm
Page 1 of 4 1234>
