Home > Technical (L322) > 4.2 supercharged misfire on idle |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1320 |
what codes were showing ie which cylinder/s were misfiring?
22nd Feb 2018 12:04am |
Dano0404 Member Since: 28 Dec 2017 Location: Uk Posts: 44 |
No codes relating to the misfire, I have had eml flashing at me a few times but just in lpg. |
22nd Feb 2018 12:16am |
suspect your lpg system is not set up to optimum and needs a service/calibration
22nd Feb 2018 2:34am |
Car has done around 20-30k on lpg. It had a flash lube system and I believe 10% petrol injection. I did think it could do with a lpg tune up but would be nice to get rid of the misfire on petrol first.
22nd Feb 2018 8:48am |
400-ascona Member Since: 25 Jan 2018 Location: Midlands Posts: 65 |
Check for leaks on the flexi pipes from the LPG injectors to the inlet manifold. They tend to stiffen over time and don't seal as well. To be honest it normally smells of LPG too if they are leaking. |
22nd Feb 2018 9:51pm |
Did you manage to sort it? |
17th Mar 2018 9:36pm |
No not yet got the lpg serviced and been the same it always has. |
19th Mar 2018 9:22pm |
Plugged in to day and seems to be miss firing down one side more than the other. Did think about ordering a couple of coil packs and trying to change a few around.
28th Apr 2019 5:21pm |
friskydog Member Since: 16 May 2018 Location: West Midlands Posts: 70 |
I am seeing very similar...
2nd Sep 2021 7:10pm |
All bank one misfires, camshaft sensor? |
2nd Sep 2021 7:36pm |
Would this be the part your refering to...
2nd Sep 2021 8:13pm |
Could be a possibility that the sensor is on its way out or the timing is slightly out on that bank after the rebuild. Try swapping sensors across banks if the problem moves to the other side you will have nailed it (thats if they are not lh and rh parts) |
2nd Sep 2021 8:44pm |
Great I will check that thank you. Range Rover Vogue SE 2007 L322 4.2 Supercharged 121k. Engine rebuilt @ 120666 Miles |
2nd Sep 2021 8:51pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8066 |
Sure I've read about this problem on USA Jaguar forums, they are the place to look at for the 4.2 and 5.0 supercharged engines as there are loads over there...
2nd Sep 2021 9:44pm |
