![]() | Home > My Range Rover > range rover with problems |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
That is a potential nightmare i would agree.
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 783 ![]() ![]() ![]() |
Yes it does make sense, thanks for your thoughts.
i contacted a seller in the states about buying the parts, it seemd like they were made in germany.
Good news on getting the bolts shifted, I hope the valves go ok, you are basically doing a leak down test but when i bought a cheap leak down tester to test my compression the air blew straight through but my compression when cranked was 170 psi + so I am not sure why or how or maybe my valves were open. Check lifters are not collapsed and then measure between the folower and the cam lobe, there should be no gap.
How are you getting on mate? |
Hi, thanks for tour interest
Getting there then, I always use an airline to blow around my spark plugs before removing them.
Trying to buy parts on ebay is proving difficult, I am trying to buy the whole kit for M62, I message the seller and they say it won’t fit, or they don’t bother answering.
They are probably worried about sending it out the country and it not arriving , what kit are you trying to buy ? |
The lower timing chain kit
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 ![]() ![]() |
Have you thought about finding a drop shipper - somewhere in the UK you can have parts from different suppliers sent to and then they package it all up and send it out to you when its all arrived so you only pay one lot of postage. I'm sure one of the site sponsors (MD Couriers) does it. Current Fleet:-
Can you not source the parts from where you are ?
yes i can i told them what i was doing and asked for a price on all the parts i needed, this is what i got RR 2005 4.4 petrol Any spelling mistakes are the fault of spellchecker Previous MG J2, CITROEN light 15 x 2 gone unfortunately Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar |
i dont know if you can read that.
