Home > My Range Rover > range rover with problems
Page 6 of 18 <123 ... 567 ... 161718>
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
This is turning in to a nightmare
Camshaft in the vice, ½ “ rattle gun won’t touch it, ¾ rattle gun won’t touch it.
Got both the inlet cams loose
Cant undo the right hand exhaust cam.
Got my son to hold the cam with the 27mm spanner (it closer to 26mm)
Tried it with the rattle gun, spanner slipt off the cam, turned the cam ½ a turn
So now I suppose I have some bent valves RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #467380 5th Feb 2018 6:26am
holidaychicken
That is a potential nightmare i would agree.
I am trying to think if you can time the engine and get the cam chains back in place with the exhaust sprockets left bolted to the camshaft but removing one or both of the cams to enable you to get the cam chains back on, does that look feasible ?
Check the procedure but i think the cams are normally removed with the crank in the 45 deg. before TDC mark but you are past that point anyway and i don't think that will cause you a problem.
Regarding a bent valve, if you can get the engine back together as far as the chains and guides and timed you can carefully wind it over by hand initially and check for any resistance and any gap with a feeler gauge between the hydraulic lifters and the cam lobes indicating the valve is not closing.
If a valve is bent then it is head off but i would get your guides sorted first and then check that.
Does any of that make sense ?
Post #467398 5th Feb 2018 11:12am
knares
Yes it does make sense, thanks for your thoughts.
I will have to look in to the hydraulic lifters and find out about them, how they work.
Some of them, I can press down on and they are springy, others feel solid
Had to go to the tool shop this morning and buy some torx bits, I never said anything about them but the guy started telling me every one is complaining about them being useless
I bought three
I have a decent three phase compressor, cranked it up to 150lb and after about the forth try with the ¾ rattle gun they let go.
Now I have both exhaust cams out and the torx bolts loose
The camshaft retainers have numbers on them but they don’t mean anything so I have had to etch numbers on them so I know where they came from.
I think my next move is to remove the inlet camshaft, make a fitting to screw in to the spark plug hole and put about ten pound pressure in the cylinder.
That should tell me if the valves are seated ok, fingers crossed RR 2005 4.4 petrol
Post #467422 5th Feb 2018 2:08pm
knares
i contacted a seller in the states about buying the parts, it seemd like they were made in germany.
his reply
These items are Bapmic brand. They are made in China.
i dont know if thats ok or not
i can get parts from china myself at about 1/3 of his price, dont know what brand RR 2005 4.4 petrol
Post #467430 5th Feb 2018 2:17pm
holidaychicken
Good news on getting the bolts shifted, I hope the valves go ok, you are basically doing a leak down test but when i bought a cheap leak down tester to test my compression the air blew straight through but my compression when cranked was 170 psi + so I am not sure why or how or maybe my valves were open. Check lifters are not collapsed and then measure between the folower and the cam lobe, there should be no gap.
The HVA or lifters or tappets or whatever people prefer to call them are basically hydraulic and fill with oil to take up the slack between the cam and the valve and shouldn't be spongy but if the car hasn't been run for a while they do leak back which can cause the start up rattle and also ongoing tapping which is when the bleed procedure can be used but that involves running the engine at 3000 rpm for a period of minutes (its online and you tube) and repeating but i dont think it lasts long term so if you have the cash i would replace them but 32 x £20 is a fair lump of cash so i might be saving until you know the valves are good. What sort of price have you seen them at ?
This is basically the tech service bulletin
http://www.enginebuildermag.com/2009/05/to...-problems/
There are a couple of you tube vids on how to clean them but I am not sure whether cleaning is effective.
Part numbers are
LGR000010 , febi - 12781, bmw - 11 32 1 440 256, (11321440256)
Bit of info here
https://www.meeknet.co.uk/E38/Tappets.htm
More info here
https://www.ebay.co.uk/itm/8x-Febi-Engine-...SwXetZXTm~
This should explain your CAM Cap numbering
Post #467455 5th Feb 2018 7:58pm
holidaychicken
How are you getting on mate?
Post #469486 20th Feb 2018 8:30pm
knares
Hi, thanks for tour interest
I have removed all the camshafts and made an air adaptor for the sparkplug.
This engine is very dirty in side, I have never seen anything like it, its like the engine oil has turned to tar.
I have had a couple of car mechanics look at it and they say not to worry, they have seen this before and the engines ran ok with no problems.
I am reluctant to take out the spark plugs until I know there is no dirt around them which could fall in to the cylinder.
When I was an apprentice, one of the younger apprentices took the spark plugs out of a jaguar, which was in for its first service and a very small brass nut fell in to the cylinder.
It kept closing up the spark plug gap, they had to take the head off to find out what was causing the problem, ended up having to hone the bore and replace the piston.
Lucky it wasn’t me.
So its always on my mind.
I have a Borescope, in fact I have two, but I cant find them, which I intend to use to look around the plugs as I cant see in there very well
I have been looking for it for a week now, if I don’t find it in the next couple of days I will buy another.
At the moment I am assembling a fordson tractor engine for a guy also RR 2005 4.4 petrol
Post #469582 21st Feb 2018 3:46pm
holidaychicken
Getting there then, I always use an airline to blow around my spark plugs before removing them.
i have seen what you describe on heads that have been up for sale. My concern would be flushing all the crap out the tiny holes that are in the tensioners and other oil ways but you should be fine with a couple of oil changes.
Post #469598 21st Feb 2018 6:57pm
knares
Trying to buy parts on ebay is proving difficult, I am trying to buy the whole kit for M62, I message the seller and they say it won’t fit, or they don’t bother answering.
Trying to message a mob in Doncaster and a message pops up saying the cant answer RR 2005 4.4 petrol
Post #473261 21st Mar 2018 6:31am
holidaychicken
They are probably worried about sending it out the country and it not arriving , what kit are you trying to buy ?
Post #473270 21st Mar 2018 8:52am
knares
The lower timing chain kit
The upper timing chain kit
Front gasket kit
Camshaft cover kits
vanos kits
cant think now of any thing else
Trying to do a one stop shop, less postage RR 2005 4.4 petrol
Post #473294 21st Mar 2018 11:03am
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
Have you thought about finding a drop shipper - somewhere in the UK you can have parts from different suppliers sent to and then they package it all up and send it out to you when its all arrived so you only pay one lot of postage. I'm sure one of the site sponsors (MD Couriers) does it. Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #473355 21st Mar 2018 7:44pm
holidaychicken
Can you not source the parts from where you are ?
When i get chance i'll find all the kit i ordered and where from so at least you have all the part numbers.
You could try britcar https://www.brit-car.co.uk/ as i have found them very good in the past for getting different brands together.
I used Febi bilstein parts in mine with the beisan seals in the vanos, do you want all genuine or a mix of quality OEM and genuine ?
Post #473358 21st Mar 2018 8:21pm
knares
yes i can
i told them what i was doing and asked for a price on all the parts i needed, this is what i got RR 2005 4.4 petrol
Post #473539 23rd Mar 2018 5:07am
knares
i dont know if you can read that.
its for
timing chain
arm tentioner
guide
tentioner-timing chain
$832.63 RR 2005 4.4 petrol
Post #473540 23rd Mar 2018 5:12am
