![]() | Home > My Range Rover > range rover with problems |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 795 ![]() ![]() ![]() |
Try driving without the Air flow meter plugged in. i did try that didnt seem to make much difference, i pulled it apart and it looked ok i did the steering thing as well RR 2005 4.4 petrol Any spelling mistakes are the fault of spellchecker Previous MG J2, CITROEN light 15 x 2 gone unfortunately Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar |
just a quick one, i reversed it back a bit to fit the wheel speed sensor
i started it this morning, it messed around as usual, when it did idle it was running rough and i remembered what you said so i puled the plug off, the revs picked up and it idled a lot better RR 2005 4.4 petrol Any spelling mistakes are the fault of spellchecker Previous MG J2, CITROEN light 15 x 2 gone unfortunately Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar |
Sandy Choda Member Since: 05 Sep 2017 Location: Stafford Posts: 17 ![]() ![]() ![]() |
Solution in my case was to replace the Air Flow Meter. When searching online try looking up the alternative part numbers. If I have the right one from LR Cat:
fitted the wheel speed sensor
Sandy Choda
rovers price for an air flow meter $340.00 RR 2005 4.4 petrol
Try ebay/gumtree for the Bosch number 0 280 217 814 or BMW part number 13 62 1 433 567 |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
https://www.aliexpress.com/item/Mass-Air-F...st=ae803_4 2007 TDV8 VSE 2003 TD6 gone. 2002 P38a gone 1999 P38a gone 1997 p38a gone 1993 VSE gone 1992 VSE gone 1966 Series 2a with V8 conversion gone |
thanks for the links guys
Not getting anywhere with this engine
its a HSE and its not licensed RR 2005 4.4 petrol
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
That’s frustrating. ______________________________
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 988 ![]() ![]() |
Vanos wont have anything todo with your problem look elseware |
