Home > My Range Rover > range rover with problems |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
That is a potential nightmare i would agree.
5th Feb 2018 10:12am |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 739 |
Yes it does make sense, thanks for your thoughts.
5th Feb 2018 1:08pm |
i contacted a seller in the states about buying the parts, it seemd like they were made in germany.
5th Feb 2018 1:17pm |
Good news on getting the bolts shifted, I hope the valves go ok, you are basically doing a leak down test but when i bought a cheap leak down tester to test my compression the air blew straight through but my compression when cranked was 170 psi + so I am not sure why or how or maybe my valves were open. Check lifters are not collapsed and then measure between the folower and the cam lobe, there should be no gap.
5th Feb 2018 6:58pm |
How are you getting on mate? |
20th Feb 2018 7:30pm |
Hi, thanks for tour interest
21st Feb 2018 2:46pm |
Getting there then, I always use an airline to blow around my spark plugs before removing them.
21st Feb 2018 5:57pm |
Trying to buy parts on ebay is proving difficult, I am trying to buy the whole kit for M62, I message the seller and they say it won’t fit, or they don’t bother answering.
21st Mar 2018 5:31am |
They are probably worried about sending it out the country and it not arriving , what kit are you trying to buy ? |
21st Mar 2018 7:52am |
The lower timing chain kit
21st Mar 2018 10:03am |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 |
Have you thought about finding a drop shipper - somewhere in the UK you can have parts from different suppliers sent to and then they package it all up and send it out to you when its all arrived so you only pay one lot of postage. I'm sure one of the site sponsors (MD Couriers) does it. Current Fleet:-
21st Mar 2018 6:44pm |
Can you not source the parts from where you are ?
21st Mar 2018 7:21pm |
23rd Mar 2018 4:07am |
i dont know if you can read that.
23rd Mar 2018 4:12am |
