![]() | Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35510 ![]() ![]() |
thanks nino, i'm up for the challange |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3551 ![]() ![]() ![]() |
o-ring job is dead easy Stan
thanks greg, but it's my articulation which is the problem...luckily i have persuaded 'number one son' to help... ... - .- -.
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 904 ![]() ![]() ![]() |
It's sometimes not that easy to tell if the leak is coming from the oil cooler or the turbo pipe.
information digested, thanks |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2274 ![]() ![]() ![]() |
Hope he isn't going to charge main dealer rates - mine seem to ![]() |
i've trained mine to be happy with a bacon butty |
i've at last had a look at the leak and now need expert opinions on whether its the 'o' ring thats leaking and pushing the oil up [arrowed] or the oil cooler above it, what do you think?
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
It will only take your mechanic son half an hour to change the Orings, so whatβs to loose?, change them and see if it stops leaking would be my choice.
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
it looks very much like top gasket is leaking, and I would replace both once you are at it.
@mike, my thoughts are the same , change the 'o' rings and see if the leak comes back but looking at ninos pics it looks like the oil gasket is the culprit ..
Nino, not only are you a very skilled mechanic, but you are a brilliant photographer ππ
Mike, I was a fashion photographer for few years while living in Chicago (1980-1999), Pay was so so but the other benefits were great . |
stoutgoose Member Since: 08 Jan 2015 Location: London Posts: 186 ![]() ![]() ![]() |
How big a job is it to remove the inlet manifold and change the oil/water heat exchanger?
