Home > Technical (L322) > 2010 Heated/Cooled Seat not working |
millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 334 |
Great write up. Ive just removed my seat back using this very method.
8th Jan 2018 6:20pm |
tj2k Member Since: 10 Dec 2017 Location: Shropshire Posts: 34 |
Take the seat back off then & see if the ducting is cracked or in anyway compromised - if it is, that’s your problem & you’ll need the seat motor regardless.
8th Jan 2018 6:33pm |
Tj2k
8th Jan 2018 6:59pm |
8th Jan 2018 7:00pm |
At first glance, that does look ok - on the surface - from what I can see (heavily caveated! ).
8th Jan 2018 7:50pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3808 |
My ducting was cracked underneath, not immediately visible, I did a bodge with gaffer tape and it didn't work - but maybe I actually bodged the job. So I will remove the whole thing and see whats what and Dan has given me a price for a replacement if I need it. I find working with the seat out to be easier and as soon as I can ident a helper thats what I'll be doing. Last time I took a seat out by myself I found it to be heavy and awkward - a bit like myself really Geoff |
8th Jan 2018 10:31pm |
Supershuttle - what did Dan quote you for a price? Is it cheaper than £209 +vat? |
8th Jan 2018 11:14pm |
tj2k
9th Jan 2018 1:14pm |
£195+ VAT Geoff |
9th Jan 2018 3:05pm |
Geoff (Supershuttle)
9th Jan 2018 3:07pm |
I did have a thought - dangerous I know - but can the thermistor itself be swapped out as they are simply temperature sensitive resistors. Or is it as I suspect (because no ones wrote it up) not easily be done ? Geoff |
11th Jan 2018 9:57am |
I did think that as well, but looking at the cell, I can’t actually work out which is the "power" and whuch would be the thermistor. I think you may very well destroy the cell trying to change it
11th Jan 2018 10:33am |
Fatfred Member Since: 15 Dec 2017 Location: essex Posts: 55 |
i will be looking forward to your update on the thermistor cell FF TDV8 WESTMINSTER EXTERIOR DESIGN PACK 2012 |
11th Jan 2018 10:59am |
Zeppfish Member Since: 28 Feb 2016 Location: Surrey Posts: 57 |
Supershuttle
12th Jan 2018 3:38pm |
