Home > My Range Rover > range rover with problems |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 748 |
thanks guys |
27th Jun 2017 10:41am |
any advice on how to go about getting the dip stick out ?? RR 2005 4.4 petrol
29th Dec 2017 8:43am |
kanikune Member Since: 29 Oct 2017 Location: Teerijarvi Posts: 28 |
Normally you can just pull it off.
29th Dec 2017 2:07pm |
i should have said dip stick tube, Apparently its held in with a nut or bolt, 9mm spanner but how do I get to it.
29th Dec 2017 11:23pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
Why do you want to take out the dipstick?
30th Dec 2017 1:20am |
got it out thanks, aq bit of friendly Persuasion RR 2005 4.4 petrol
30th Dec 2017 3:29am |
I got mine out with a bit of friendly persuasion, it was getting it back in that was probably the hardest part of my timing chain and vanos rebuild |
30th Dec 2017 8:09am |
I was watching a video last week, the guy, at the end of the video said, you cant use Chinese cam timing tools because it will show up as a fault.
31st Dec 2017 4:55am |
Looking at the timing chain guides on ebay, it looks like the left one is all plastic, anyone know if a metal based one is available RR 2005 4.4 petrol
31st Dec 2017 8:26am |
They are all aluminum backed plastic, i used febi bilstein ones in mine.
31st Dec 2017 12:52pm |
i made some retaining blocks out of tubing and an old spark plug, not that i needed to, i just did.
6th Jan 2018 11:08am |
But i have to tell you now even though you don't need to know !
6th Jan 2018 1:15pm |
i see, so they do have a retaning clamp
6th Jan 2018 2:17pm |
They do but i don't think most people use them as they don't come with the cheap timing kits.
6th Jan 2018 2:23pm |
