![]() | Home > My Range Rover > range rover with problems |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 739 ![]() ![]() ![]() |
thanks guys |
any advice on how to go about getting the dip stick out ?? RR 2005 4.4 petrol
kanikune Member Since: 29 Oct 2017 Location: Teerijarvi Posts: 28 ![]() ![]() ![]() |
Normally you can just pull it off.
i should have said dip stick tube, Apparently its held in with a nut or bolt, 9mm spanner but how do I get to it.
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
Why do you want to take out the dipstick?
got it out thanks, aq bit of friendly Persuasion RR 2005 4.4 petrol
I got mine out with a bit of friendly persuasion, it was getting it back in that was probably the hardest part of my timing chain and vanos rebuild |
I was watching a video last week, the guy, at the end of the video said, you cant use Chinese cam timing tools because it will show up as a fault.
Looking at the timing chain guides on ebay, it looks like the left one is all plastic, anyone know if a metal based one is available RR 2005 4.4 petrol
They are all aluminum backed plastic, i used febi bilstein ones in mine.
i made some retaining blocks out of tubing and an old spark plug, not that i needed to, i just did.
But i have to tell you now even though you don't need to know !
i see, so they do have a retaning clamp
They do but i don't think most people use them as they don't come with the cheap timing kits.
