![]() | Home > My Range Rover > range rover with problems |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
cool, good luck |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 788 ![]() ![]() ![]() |
I have the timing covers off
Where are the cams regarding advance / retard ?
i would have to turn the exhaust cam 1to4 about a tooth clockwise to get it to fit. I have removed the locking cap head screw altogether and tried to fit them inderpendently RR 2005 4.4 petrol Any spelling mistakes are the fault of spellchecker Previous MG J2, CITROEN light 15 x 2 gone unfortunately Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar |
That kit is not for your engine, that is for the later Jag engines, yours is the M62TUB44 bmw engine.
I tried to contact FEBI
I also thought that febi was made in germany but as with most manufacturers they probably have some product made in china but it could be that due to location they are responsible for supplying Australia, why did you need to contact them ?
&t=806s
The beisan website does it in a slightly different order in that they lock the cams in place before removing the timing plate and loosening the vanos torx bolts -
holidaychicken
thats interesting, the plot thikens, the rover people told me the "5A" in the vin no means the engine is 2005 to 2010 i thought the engine was a Engine M62 B44 4.4V8 RR 2005 4.4 petrol Any spelling mistakes are the fault of spellchecker Previous MG J2, CITROEN light 15 x 2 gone unfortunately Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar Last edited by knares on 11th Jan 2018 3:43am. Edited 1 time in total |
"why did you need to contact them ?"
