Home > Technical (L322) > Iidtool key programming |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 |
so its not clicking as you insert the key pal ? |
18th Dec 2017 4:01pm |
SteveRRL322 Member Since: 23 Oct 2016 Location: Kent Posts: 128 |
No, if you put in the old key you hear it disengage the steering lock but the new one
18th Dec 2017 4:23pm |
the car isn't recognising the new key then ( obviously ) there must be a way of opening comms to allow for the the pairing of new keys though |
18th Dec 2017 4:26pm |
Hi
18th Dec 2017 6:21pm |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
Does the key work in the door lock? 2015 4.4 AB
18th Dec 2017 6:29pm |
Yes it locks and unlocks the doors |
18th Dec 2017 6:59pm |
Just trying to rule out the phyiscal key 2015 4.4 AB
18th Dec 2017 7:09pm |
Just trying to rule out the phyiscal key . Which iid tool do you have ? 2015 4.4 AB
18th Dec 2017 7:12pm |
18th Dec 2017 7:15pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Have you tried putting the new key into the ignition then putting the coded key as close as you can to the ignition to trick the ignition into turning off the steering lock, then turn the uncoded key, then remove the coded key are voila your ignition is on and your uncoded key is in the ignition ready for IID to code it |
18th Dec 2017 11:19pm |
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 745 |
Wish I lived near you!
19th Dec 2017 10:13am |
I have a 2017 BT iidtool from Dan. The coding part is easy it's just that you need to turn the key and I don't know
19th Dec 2017 7:22pm |
bob-lad Member Since: 12 Jun 2015 Location: Herefordshire Posts: 91 |
And what if you have a 2010+ with push button start ? |
20th Dec 2017 10:38pm |
For push button start its incredibly easy. Takes about 30 seconds from start to finish with my IID tool. I programmed a new shape ( smaller ) key. The original key isnt even used. I now have a spare at home and in the office. Proberbly lose the one im using when im out now !!!! 2015 4.4 AB
20th Dec 2017 10:42pm |
