Home > Technical (L322) > Iidtool key programming
SteveRRL322
Good Afternoon,
I have just bought a flip key with transponder built in. I have had the blade cut and have
Programmed it to lock and unlock so the next stage is to programme the transponder.
My gap tool does this but you need to turn the new key to position one and for some reason
It will not turn in the lock to disengage the steering lock. Could this be a badly cut key or I thought
It was the chip inside the key which cancels the steering lock?
Any ideas?
Thanks in advance
Steve
Post #461267 18th Dec 2017 3:41pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
so its not clicking as you insert the key pal ?
Post #461273 18th Dec 2017 4:01pm
SteveRRL322
No, if you put in the old key you hear it disengage the steering lock but the new one
Doesnโ€™t make any noise. The new key will open and close the drivers door but maybe the ignition
Is more sensitive?
Thanks
Post #461277 18th Dec 2017 4:23pm
bembo449
the car isn't recognising the new key then ( obviously ) there must be a way of opening comms to allow for the the pairing of new keys though
Post #461278 18th Dec 2017 4:26pm
SteveRRL322
Hi
That's what the iidtool does it codes new transponders but it won't do it if the key won't turn
Post #461295 18th Dec 2017 6:21pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Does the key work in the door lock? 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #461297 18th Dec 2017 6:29pm
SteveRRL322
Yes it locks and unlocks the doors
Post #461304 18th Dec 2017 6:59pm
dolph34
Just trying to rule out the phyiscal key 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #461306 18th Dec 2017 7:09pm
dolph34
Just trying to rule out the phyiscal key . Which iid tool do you have ? 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #461307 18th Dec 2017 7:12pm
dolph34
 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #461308 18th Dec 2017 7:15pm
Have you tried putting the new key into the ignition then putting the coded key as close as you can to the ignition to trick the ignition into turning off the steering lock, then turn the uncoded key, then remove the coded key are voila your ignition is on and your uncoded key is in the ignition Thumbs Up ready for IID to code it Thumbs Up
Post #461356 18th Dec 2017 11:19pm
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
Wish I lived near you!
Great knowledge Bow down
Merry Christmas Craig Thumbs Up 2014 vogue se
Post #461379 19th Dec 2017 10:13am
SteveRRL322
I have a 2017 BT iidtool from Dan. The coding part is easy it's just that you need to turn the key and I don't know
If that's a key cutting problem or the transponder that unlocks the steering column. If that's the case then it's abit chicken and egg if you need a valid transponder to unlock the column to programme the key.
I have tried having both keys together Craig but it didn't unlock, but maybe I need to try it a few more times ๐Ÿ‘
Might get lucky.
I have also ordered a new key blade as it looks like the key cutter has cut it too deep as there is a pin prick hole
In it but it still opens the door? Maybe the transmission lock is more sensitive. I will get the blade recut anyway
To rule that out.
Thanks for all the suggestions guys I will crack it soon ๐Ÿ˜„
Cheers guys
Post #461457 19th Dec 2017 7:22pm
bob-lad
And what if you have a 2010+ with push button start ?
Post #461583 20th Dec 2017 10:38pm
dolph34
For push button start its incredibly easy. Takes about 30 seconds from start to finish with my IID tool. I programmed a new shape ( smaller ) key. The original key isnt even used. I now have a spare at home and in the office. Proberbly lose the one im using when im out now !!!! 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #461584 20th Dec 2017 10:42pm
