Home > Technical (L322) > Webasto T91 changing to heat question |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35331 |
is not the mode automatic, heat below 16 degrees and ventilation above 16 degrees.. ... - .- -.
15th Nov 2017 2:47pm |
Gumball3000 Member Since: 11 Mar 2017 Location: Liverpool Posts: 200 |
No mention in the instructions.
15th Nov 2017 2:55pm |
where it says ,
15th Nov 2017 3:15pm |
Can anyone who has a t91 system on a full fat confirm that only the green light works ?? |
15th Nov 2017 7:44pm |
Pvw10 Member Since: 04 Nov 2015 Location: Ledbury Posts: 315 |
Mine purely the green line on, red off. Many thanks
15th Nov 2017 7:45pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3236 |
^^^^ +1 John
15th Nov 2017 8:03pm |
green is for connection
15th Nov 2017 8:06pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
Funny I was just reading the Webasto manual and thinking I was going mad re LEDs and change over mode. So the RR operation seems quite different to the standard.
15th Nov 2017 8:53pm |
Thanks for all the replys guys, so it seems like mine works as it should (for the rr anyway)
16th Nov 2017 9:30am |
inside temp controls turned up? ... - .- -.
16th Nov 2017 9:31am |
Yep both on hot. |
16th Nov 2017 9:33am |
TomCobbly Member Since: 29 Jun 2016 Location: Guildford Posts: 122 |
Just because the fan is blowing it doesn't mean it the FBH has fired up. Can you also hear a tick tick tick from the solenoid fuel pump or see/smell exhaust fumes?
16th Nov 2017 2:58pm |
Did a test this afternoon and i 'think' i know what the problem is.
16th Nov 2017 4:21pm |
you'll get that 'low battery shut off' warning even if the battery is ok... if the engine isnt running then the FF shuts all the electronics off after about ten minutes or so... ... - .- -.
16th Nov 2017 4:25pm |
