![]() | Home > Technical (L322) > Webasto T91 changing to heat question |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
is not the mode automatic, heat below 16 degrees and ventilation above 16 degrees.. ... - .- -.
Gumball3000 Member Since: 11 Mar 2017 Location: Liverpool Posts: 200 ![]() ![]() ![]() |
No mention in the instructions.
where it says ,
Can anyone who has a t91 system on a full fat confirm that only the green light works ?? |
Pvw10 Member Since: 04 Nov 2015 Location: Ledbury Posts: 315 ![]() ![]() ![]() |
Mine purely the green line on, red off. Many thanks
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3244 ![]() ![]() ![]() |
^^^^ +1 John
green is for connection
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
Funny I was just reading the Webasto manual and thinking I was going mad re LEDs and change over mode. So the RR operation seems quite different to the standard.
Thanks for all the replys guys, so it seems like mine works as it should (for the rr anyway)
inside temp controls turned up? ... - .- -.
Yep both on hot. |
TomCobbly Member Since: 29 Jun 2016 Location: Guildford Posts: 122 ![]() ![]() ![]() |
Just because the fan is blowing it doesn't mean it the FBH has fired up. Can you also hear a tick tick tick from the solenoid fuel pump or see/smell exhaust fumes?
Did a test this afternoon and i 'think' i know what the problem is.
you'll get that 'low battery shut off' warning even if the battery is ok... if the engine isnt running then the FF shuts all the electronics off after about ten minutes or so... ... - .- -.
