![]() | Home > Technical (L322) > Webasto T91 changing to heat question |
Zeppfish Member Since: 28 Feb 2016 Location: Surrey Posts: 57 ![]() ![]() ![]() |
Gumball
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 ![]() ![]() ![]() |
What fuse number for the FBH on a 2012?
Not sure what fuse it is! The webasto manual mentions a 20a fuse so it could be that one? Only way to tell for sure would be pull it out, and try the manual heat/fob and if there is nothing at all it must be the one! 2006 RR sport HSE
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
GiantLM - that seems to be a 405 manual... I was hunting for my fuse, I think it's in the engine bay fusebox:
Problem is I don't know which one. Might be 3 or 19. Also, I can watch around 25-30 of TV until the Low Battery warning comes up. Not running heater. Greg Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
Worth noting pulling the fuse is not guaranteed to reset the FBH fault if its locked out. Better to get a cheaper code reader/clearer |
Cheers for that, Zeppfish. Very logical.
I would try fuse 13! 2006 RR sport HSE
Mine's been sporadic;
Heathy Member Since: 19 Feb 2017 Location: Marks Tey, Essex Posts: 53 ![]() ![]() ![]() |
Following with interest... Vogue SE 2011 MY 4.4TDV8 in Fuji White
Gumball3000 Member Since: 11 Mar 2017 Location: Liverpool Posts: 200 ![]() ![]() ![]() |
Well following a brand new battery mine now does this -
Following a bit of doubt a couple of posts up ^^ as to which symbol related to the FBH fuse, the fuse is marked 13E 20A on this wiring diagram:
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 ![]() ![]() ![]() |
The FBH is the same as the Rover 75,
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 818 ![]() ![]() |
Or simply the battery charge is low and the system shuts itself down
Seems like this is the same issue i am having , how do i fix it ? |
