Home > Technical (L322) > Webasto T91 changing to heat question
Page 1 of 3 123>
Gumball3000
United Kingdom 2011 Range Rover Vogue SE TDV8 Zermatt Silver
HI guys,
I have a 2011my Full fat tdv8 , it has the T91 fbh system fitted , the car didnt come with a fob. I have since got one and a brand new battery . I have successfully paired the fob with the car and have heard the fuel burner in the car fire up.
The problem i am having is i cant select heat mode (red led) i have done what the webasto pdf instructions say to do , which is hold both button down to see what mode its in. But when i do this nothing happens.
When i press on the green led lights up and then flashed every 2 secs or so , but thats it.
Please help me ............ Big Cry Big Cry Big Cry
Post #457390 15th Nov 2017 2:36pm
is not the mode automatic, heat below 16 degrees and ventilation above 16 degrees.. ... - .- -.
Post #457391 15th Nov 2017 2:47pm
Gumball3000
No mention in the instructions.
https://www.webasto.com/fileadmin/webasto_...rt-t91.pdf
Post #457392 15th Nov 2017 2:55pm
where it says ,
A mode change on the transmitter is not required for this purpose, as the "parking heating" or "parking
ventilation" function is determined by the switch position of the summer/winter switch.
pretty sure the FF has this 'auto' switch'.... ... - .- -.
Post #457396 15th Nov 2017 3:15pm
Gumball3000
Can anyone who has a t91 system on a full fat confirm that only the green light works ??
Post #457429 15th Nov 2017 7:44pm
Pvw10
United Kingdom 2014 Range Rover Vogue SE SDV8 Firenze Red
Mine purely the green line on, red off. Many thanks
Paul
Post #457430 15th Nov 2017 7:45pm
Weegie
^^^^ +1 John
GAP iiD BT
Post #457431 15th Nov 2017 8:03pm
green is for connection
red for lost connection
and amber for replace battery....
theres a fbh explanation in the wiki.. ... - .- -.
Post #457433 15th Nov 2017 8:06pm
GGDR
Funny I was just reading the Webasto manual and thinking I was going mad re LEDs and change over mode. So the RR operation seems quite different to the standard.
. Cheers, Greg
Post #457438 15th Nov 2017 8:53pm
Gumball3000
Thanks for all the replys guys, so it seems like mine works as it should (for the rr anyway)
So i pressed the fob this morning , heard the burner fire up and run , 25 mins later goes out to leave the house and guess what ??? the car is still cold inside .........
Where do i go from here , i have stood outside and heard the burner running so its not that , what else could be the problem ??
Post #457470 16th Nov 2017 9:30am
inside temp controls turned up? ... - .- -.
Post #457471 16th Nov 2017 9:31am
Gumball3000
Yep both on hot.
Post #457472 16th Nov 2017 9:33am
TomCobbly
Just because the fan is blowing it doesn't mean it the FBH has fired up. Can you also hear a tick tick tick from the solenoid fuel pump or see/smell exhaust fumes?
Mine works perfectly until the battery voltage drops a bit then switches off to preserve starting so you need a good battery fully charged.
On the 2011 4.4TDV8 the iiD tool can read error codes from the FBH iirc. Might be worth a try. 2011 4.4 TDV8 Vogue SE
1993 Discovery 1 3.5 V8i
Post #457521 16th Nov 2017 2:58pm
Gumball3000
Did a test this afternoon and i 'think' i know what the problem is.
I sat in the car and pressed the on button on the t91 remote, i heard the burner fire up and a ticking from the rear.
Then after a few minutes the burner slowly went quieter then seemed to go off.
So i decided to leave it and watch some tv in the car whilst i waited for my daughter to come out of school.
Only after a few minutes a message popped up on the screen saying ' low battery shutting down'
So i am guessing my battery is near the end of its life , the car starts perfect every day , but i am guessing its the original battery as the car is an 2011 model.
So maybe time for a new one before it dies.
Post #457527 16th Nov 2017 4:21pm
you'll get that 'low battery shut off' warning even if the battery is ok... if the engine isnt running then the FF shuts all the electronics off after about ten minutes or so... ... - .- -.
Post #457528 16th Nov 2017 4:25pm
Page 1 of 3 123>
