Home > Maintenance & Mods (L322) > CSOV valve\turbo drain drill
DaveAngel
2015 Range Rover Vogue SE SDV8 Barolo Black
Does anybody have some ideas about how much it should cost for a turbo drain drilling on a 4.4TD?
Been quoted silly money by the main dealer and got to go and find an indi around Hampshire that can do this for me.
Thanks,
Dave __________________
2015 FFRR SDV8
2011 FFRR TDV8 4.4 - Gone
2005 FFRR TDV6 - Gone
Post #450568 11th Sep 2017 3:53pm
do you actually need the modification Dave...if yours doesn't produce smoke on hard acceleration (over 2500 rpm) then you don't need the mod.. ... - .- -.
Post #450571 11th Sep 2017 3:57pm
DaveAngel
Thanks Stan,
Its not smoking, wife does alot of short journeys, so the oil has blown the seal, apparently the valve itself is OK.
Not getting any smoke, but anything upwards of 2500 revs and the restricted performance warning comes up and it goes into limp mode. __________________
2015 FFRR SDV8
Post #450574 11th Sep 2017 3:59pm
DaveAngel
Here is the job sheet they gave me... __________________
2015 FFRR SDV8
Post #450580 11th Sep 2017 4:25pm
Baltic Blue
Did they check the 4 short rubber hoses on the manifold?
It is a very common cause of restricted performance alarm at 2500 rpm. When 1 splits.
Cheers. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #450581 11th Sep 2017 4:39pm
DaveAngel
That didn't work did it.
Says
P006A-00 MAP AIR FLOW CORRELATION. Carried out visual inspection of the CSOV valve contaminated with oil. Recommend replacement of valve and carry out N/S Turbo drain modification __________________
2015 FFRR SDV8
Post #450582 11th Sep 2017 4:39pm
DaveAngel
Yeah, they checked that - they confirmed that the it was uneven airflow and under investigation confirmed that the valve wasn't opening, and that itself was swollen with oil.
Wouldn't mind as much but not 2 days ago, they stung us for £500 quid for the EGR temperature sensor, and our select warrentee doesn't cover either Shocked __________________
2015 FFRR SDV8
Post #450584 11th Sep 2017 4:41pm
Baltic Blue
Someone on here was charged £1,000 by an indi for the mod., but I think it was North Yorks, so quite a trip. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #450585 11th Sep 2017 4:58pm
Mikey
Says
Generally, a correlation fault is caused by a Boost leak...
I'd be inclined to have the inlet system smoke tested to detect any leaks Thumbs Up
Post #450589 11th Sep 2017 6:09pm
cass
Mine cost just under £1000 at an indy but that was just for the turbo drain mod, the changover valve would be in addition
Post #450590 11th Sep 2017 6:27pm
Baltic Blue
The technical bulletin quotes 1.1 hour labour to replace the CSOV. Not a difficult job.
Dan would be able to give the cost of the replacement valve.
I have got a paper copy of the bulletin if it helps you. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #450602 11th Sep 2017 7:18pm
CS
I was told the drain mod was "an eight hour job". My turbo was checked today and the leak had apparently not got worse, so it will just be monitored. Only Range Rovers since 1988
Post #450608 11th Sep 2017 7:36pm
DaveAngel
Well, thanks for all the advise guys, and you were right.
Dealers came back with a quote for 2.5k in the end, and rang around, and found an indi - Keith Gott, who offered to do it for about a grand less. Dropped it in to them yesterday, and was presently surprised for one of their tech's 'Mike' to call me a couple of hours later and tell me it was a turbo hose. They swapped it over, cleaned out the DPF and she is running like a dream, and cost me less than a tenth of the dealer quote.
Credit where its due they really know there stuff, based just outside of Winchester and after dealing with them would recommend them to anyone in the area.
On a side note, there yard is like a landy paradise with dozens of green badges, from the latest FullFats to Forward Controls! __________________
2015 FFRR SDV8
Post #451742 22nd Sep 2017 2:24pm
GGDR
Mikey a few posts up was right!
Glad you got it sorted Dave. So was it around £250 then?
Greg Cheers, Greg
Post #451826 23rd Sep 2017 12:48pm
Ukandrewf
My csov valve has stuck and is being replaced under a warranty direct warranty.
(Actually should say that Warranty Direct have probably covered more in costs for me on one MD visit that it cost me and I still have two years of cover left - I’m glad i took out the cover - although for a ‘gold plated’ cover they didn’t cover everything which was wrong and JLR had to give me a bit of goodwill. For example WD exclude their whole exhaust system from the warranty which suprised me.)
What’s the ‘ turbo drain mod’
Andrew --
On my third Full Fat RR
Post #597366 13th Jun 2021 7:43pm
