Home > Maintenance & Mods (L322) > CSOV valve\turbo drain drill |
DaveAngel Member Since: 15 Aug 2011 Location: Cowplain, UK Posts: 205 |
Does anybody have some ideas about how much it should cost for a turbo drain drilling on a 4.4TD?
11th Sep 2017 3:53pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35262 |
do you actually need the modification Dave...if yours doesn't produce smoke on hard acceleration (over 2500 rpm) then you don't need the mod.. ... - .- -.
11th Sep 2017 3:57pm |
Thanks Stan,
11th Sep 2017 3:59pm |
Here is the job sheet they gave me... __________________
11th Sep 2017 4:25pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3763 |
Did they check the 4 short rubber hoses on the manifold?
11th Sep 2017 4:39pm |
That didn't work did it.
Yeah, they checked that - they confirmed that the it was uneven airflow and under investigation confirmed that the valve wasn't opening, and that itself was swollen with oil.
11th Sep 2017 4:41pm |
Someone on here was charged £1,000 by an indi for the mod., but I think it was North Yorks, so quite a trip. G reg 2.5VM Vogue Portofino red 1991- 1999
11th Sep 2017 4:58pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1745 |
Generally, a correlation fault is caused by a Boost leak... I'd be inclined to have the inlet system smoke tested to detect any leaks |
11th Sep 2017 6:09pm |
The technical bulletin quotes 1.1 hour labour to replace the CSOV. Not a difficult job.
11th Sep 2017 7:18pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1373 |
I was told the drain mod was "an eight hour job". My turbo was checked today and the leak had apparently not got worse, so it will just be monitored. Only Range Rovers since 1988 |
11th Sep 2017 7:36pm |
Well, thanks for all the advise guys, and you were right.
22nd Sep 2017 2:24pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3542 |
Mikey a few posts up was right!
23rd Sep 2017 12:48pm |
Ukandrewf Member Since: 29 May 2013 Location: South bucks Posts: 215 |
My csov valve has stuck and is being replaced under a warranty direct warranty.
13th Jun 2021 7:43pm |
