![]() | Home > Maintenance & Mods (L322) > CSOV valve\turbo drain drill |
DaveAngel Member Since: 15 Aug 2011 Location: Cowplain, UK Posts: 205 ![]() ![]() |
Does anybody have some ideas about how much it should cost for a turbo drain drilling on a 4.4TD?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
do you actually need the modification Dave...if yours doesn't produce smoke on hard acceleration (over 2500 rpm) then you don't need the mod.. ... - .- -.
Thanks Stan,
Here is the job sheet they gave me... __________________
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Did they check the 4 short rubber hoses on the manifold?
That didn't work did it.
Yeah, they checked that - they confirmed that the it was uneven airflow and under investigation confirmed that the valve wasn't opening, and that itself was swollen with oil.
Someone on here was charged £1,000 by an indi for the mod., but I think it was North Yorks, so quite a trip. G reg 2.5VM Vogue Portofino red 1991- 1999
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1784 ![]() ![]() |
Generally, a correlation fault is caused by a Boost leak... I'd be inclined to have the inlet system smoke tested to detect any leaks ![]() |
The technical bulletin quotes 1.1 hour labour to replace the CSOV. Not a difficult job.
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1392 ![]() ![]() ![]() |
I was told the drain mod was "an eight hour job". My turbo was checked today and the leak had apparently not got worse, so it will just be monitored. Only Range Rovers since 1988 |
Well, thanks for all the advise guys, and you were right.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
Mikey a few posts up was right!
Ukandrewf Member Since: 29 May 2013 Location: South bucks Posts: 246 ![]() ![]() ![]() |
My csov valve has stuck and is being replaced under a warranty direct warranty.
