Home > Technical (L322) > Check Coolant Message |
Jonno Member Since: 08 Jun 2011 Location: Eastnor HR8 Posts: 191 |
The level sensor in the tank is tired. 5.0 supercharged autobiography
6th Sep 2017 5:37am |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 |
new tank off fleebay with sensor is £24 as ive just had the same problem , I belive the sensor can also be bought separately |
6th Sep 2017 12:47pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
Juno,
6th Sep 2017 2:14pm |
forever Member Since: 06 Oct 2015 Location: Oxted Posts: 319 |
Thanks folks will give it a go... |
8th Sep 2017 2:47pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7812 |
I believe you also get that message if the antifreeze strength is not right... but might be wrong. 2011 Range Rover Vogue SE 4.4 TDV8
8th Sep 2017 2:56pm |
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 |
I had similar and the level dropped once and then the light flashed on a few times after. Radiator was leaking on the offside join. I was lucky it didn't fail completely as I had just left the Czech Republic and had to drive 800 miles home!
8th Sep 2017 2:57pm |
