Home > Technical (L322) > Check Coolant Message
forever
A check Coolant message has appeared a few times on my 4.2 s/c it goes away and checking the coolant level via the reservoir shows its on the max level, any clues folks???
Thx
Post #449994 5th Sep 2017 8:21pm
Jonno
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Causeway Grey
The level sensor in the tank is tired. 5.0 supercharged autobiography
Gone-4.4 Vogue Lpg now unmapped
4.6 HSET Turbo Lpg mapped
Gone-Defender 90 200tdi
Gone - 3.9 Sprintex supercharged LPG
Gone - 3.9 Vogue LPG
Post #450003 6th Sep 2017 5:37am
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
new tank off fleebay with sensor is £24 as ive just had the same problem , I belive the sensor can also be bought separately
Post #450042 6th Sep 2017 12:47pm
nino_nino
Juno,
this is what i did - http://www.fullfatrr.com/forum/topic43284.html.
Jo90 did nice writeup on removing sensor, it is in the wiki. http://www.fullfatrr.com/forum/topic20913.html
nino
Post #450049 6th Sep 2017 2:14pm
forever
Thanks folks will give it a go...
Post #450273 8th Sep 2017 2:47pm
mjdronfield
I believe you also get that message if the antifreeze strength is not right... but might be wrong. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #450274 8th Sep 2017 2:56pm
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
I had similar and the level dropped once and then the light flashed on a few times after. Radiator was leaking on the offside join. I was lucky it didn't fail completely as I had just left the Czech Republic and had to drive 800 miles home!
cheers Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #450275 8th Sep 2017 2:57pm
