Home > Technical (L322) > Reduced Performance |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 |
Got it back yesterday. New exhaust temp sensor and new valve in the turbo system, not got full details yet.
13th Aug 2014 8:40am |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 |
Hi all,
3rd Jul 2017 4:41pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8523 |
thats strange, as you had the DPF warning you might assume that its related.
3rd Jul 2017 7:03pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3772 |
I think that you can rule out the air change -over valve sticking because that definitely brought up a clear fault code and the fact that you were able to rev it beyond 2,500 RPM without getting the "reduced performance " warning.
3rd Jul 2017 7:22pm |
Yes I know! Nothing on a fault scan with the IID!
3rd Jul 2017 7:26pm |
No I haven't had more than a quick visual check and feel. As I said it was all so hot when I opened the bonnet when I got home. I'll have to nurse it all week and strip the manifold off for starters and check for cracks in it and the four rubbers too.
3rd Jul 2017 7:43pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
stu, why not try battery disconnect firs. it may need that to clear previous faults. |
3rd Jul 2017 8:33pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2485 |
There's a setting on the IIDtool which when not set doesn't show some faults. I can't remember the setting but my tool with original settings wouldn't show faults that my Faultmate showed existed. |
3rd Jul 2017 8:46pm |
Nino, do you mean a hard reset, when you let it all power down then touch the battery leads together?
3rd Jul 2017 9:01pm |
stu,
4th Jul 2017 8:19am |
I have sent message to GAP this morning explaining things see what they have to say thanks again Current: TDV8 (3.6) RRS HSE
4th Jul 2017 9:13am |
Just an update, I have been doing ping pong emails with Patrick @ GAP over the last couple of days. Thanks to his fabulous IID tool and his knowledge I now have the tool set up as he recommended and it is at last picking up the fault for my restricted performance issue and it looks like it will be an air leak on the inlet after all. Be ripping the FF to bits tomorrow and trying to find the culprit. Current: TDV8 (3.6) RRS HSE
5th Jul 2017 6:48pm |
Probably one of the rubbers
5th Jul 2017 7:32pm |
the "new" rubbers look like just ordinary automotive type rubber pipe. so why not go to automotive store and bay 12~14" of pipe and cut to size, reuse Jubly clips and get new EGR gasket. cost ~15 Pounds? |
6th Jul 2017 10:53am |
