Home > Technical (L322) > 4.4 TDV8 MAP sensor
Page 4 of 10 <12345678910>
Baltic Blue
I doubt yours will be dirtier or more blocked up than either mine or NMJ's and neither of us have reported any restricted performance alarms, so I doubt it. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #443507 4th Jul 2017 11:16am
nino_nino
BB
I wish I could have seen the smile on your face -ear to ear Laughing
now this are the pictures you ask for:
in this pic. i markt the things to remove, move, disconnect.
note vacuum pipe to be disconnected
be very careful when handling butterfly as not to strip the servo gears. i used toothbrush dipped in brake cleaner and lint free cloth to clean. i do not use any lubricant.
stu, as BB has said, none of us had warning or fault reported and all our sensors where the same.
I bet you a pint of lager that battery disconnect will sort you out. Thumbs Up
BB i would like to do software update on my to. what is the Land Rover cod for it. we have no dealers in Bosnia so i will have to go to germany or italy for that, or maybe I'll just drive up to UK Very Happy . I do have Queen's passport Thumbs Up
Post #443528 4th Jul 2017 3:58pm
Baltic Blue
Nino Nino,
I come home with a smile on my face after every trip, I just love the car.
The software update is detailed in LTB 00454, but sorry, I do not have a copy to post. ( Someone may be able to help.)
Thank you for the brilliant pictures. I will be having a look to clean mine out soon.
Cheers & best wishes.
Post #443533 4th Jul 2017 4:31pm
I need to re arrange some of the pipework in this area.... the feed coming off the rad hose which goes to the left hand of the green circles, is the wrong side of the other hose, which is then chaffing on the engine cover. Good to know this push fit connection can be taken off cos I can then put it back in the right place so it sits in the channel on the foam padding Thumbs Up Thumbs Up
if I'm correct, and I might not be, the sensor attached to the plastic intake duct is the MAF? in which case this might benefit from a clean as well...... can't remember if it comes out of the housing though, the electrical connector comes off but IIRC I broke it trying to get it out when I swapped the turbo hose (the o ring was leaking where it joins to the throttle body). There is nothing that can't be fixed with a hammer😜😜
Post #443549 4th Jul 2017 6:57pm
stu
Battery disconnection it is first then. How do I get the lager to Bosnia if your right? Will Hekwap do?... Thumbs Up Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #443550 4th Jul 2017 7:24pm
nino_nino
Hekwap will do just fine stu Very Happy Thumbs Up
nmj. i do believe that is MAF sensor and i did spray some brake cleaner over it.
Post #443561 4th Jul 2017 8:18pm
GraemeS
Mine too!
Post #443564 4th Jul 2017 8:53pm
done mine today and it was clogged up like all yours..
what does this thing do again Embarassed Mr. Green ... - .- -.
Post #443609 5th Jul 2017 11:37am
Baltic Blue
I found this link posted by rar110 helpful.
http://www.aa1car.com/library/map_sensors.htm G reg 2.5VM Vogue Portofino red 1991- 1999
Post #443611 5th Jul 2017 11:43am
thank you mike...i should really have read the thread again Embarassed ... - .- -.
Post #443613 5th Jul 2017 11:46am
so would a clogged up sensor really make that much of a difference in the performance of this engine...anyone found the engine more responsive after a clean... ... - .- -.
Post #443618 5th Jul 2017 11:59am
Baltic Blue
I cleaned mine at the weekend then had the 80mph cough software update done on Monday so I can't really say which had the most effect, but it was certainly running well yesterday.
I am off down to Wimbledon next weekend so will be giving it a good run down the M6 / M40 .
I will check fuel consumption and report back . G reg 2.5VM Vogue Portofino red 1991- 1999
Post #443623 5th Jul 2017 12:25pm
mpirie
I don't think it would make much difference Stan.
As it's a pressure sensor, providing it's not sealed from the pressure in the inlet manifold, then having soot all over it would only have a minimal effect.
Post #443628 5th Jul 2017 12:43pm
looking forward to your report mike #1 .. Thumbs Up
mike #2, if thats the case then a clean sensor might give you the impression the engines running better Laughing .. ... - .- -.
Post #443631 5th Jul 2017 1:09pm
nino_nino
O she does, Very Happy Very Happy
Post #443701 6th Jul 2017 10:57am
