Home > Maintenance & Mods (L322) > Reverse lamp upgrade bulbs? |
dognero Member Since: 27 Jul 2016 Location: durham Posts: 41 |
New kit came today.
26th Oct 2016 6:52pm |
Bluegreygreen Rangie Member Since: 10 Aug 2012 Location: Australia Posts: 53 |
They look pretty darn good
12th Nov 2016 4:14pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35377 |
craig had these in a couple of his chariots... ... - .- -.
12th Nov 2016 4:31pm |
babagee Member Since: 15 Feb 2015 Location: Somewhere between St. Helens & Kazakhstan Posts: 142 |
I've fitted these and the reversing lightt output is very good and a great improvement on standard output Mine also flash in time with the indicators but led red - a bit to policey (?) but have been through 2 MOTs with no issues |
12th Nov 2016 10:19pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
^^ A box of matches is an improvement on standard
12th Nov 2016 10:47pm |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1431 |
Anyone know whether you can buy reversing lamps which have already been converted?
13th Nov 2016 9:46am |
I have only ever seen one set for sale that weren't attached to a car. No one is producing them as the ffrr isn't a high volume car, so the only lights that are available to convert are OEM... with the LR price tag
13th Nov 2016 10:36am |
it would be a seller if someone [in china?] produced a led equivalent ... even a slightly smaller unit would look nice .. ... - .- -.
13th Nov 2016 3:44pm |
Interesting, Thank you. Not sure im too keen on them flashing red. Be great if they made them just with white led for reverse 2010 TDV8 Autobiography Past - 02 & 03 TD6 And an 1984 Classic GAP Diagnostics |
13th Nov 2016 4:13pm |
^^ If your fitting those, don't forget to add Red Reflectors to keep on the right side of the law Yesterday I couldn't spell Engineer... Today I are one!
13th Nov 2016 8:18pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
Do these flash as the car sends a test pulse around the car to locate dud incandescent bulbs? ______________________________
5th Dec 2016 11:21am |
they shouldn't, but it really depends on what you wire them to, the reverse lights are not monitored by the LCM Yesterday I couldn't spell Engineer... Today I are one!
5th Dec 2016 1:54pm |
Thanks miggit. I assume the LCM sends a pulse to the brake light? And that without without a diode will flash like my LED trailer lights? ______________________________
6th Dec 2016 9:08am |
Yes Bud, the LCM, or Light Control Module, repeatedly sends very short pluses to the lights to make sure that the circuit is still working correctly, i.e. the bulb is still functioning and there isn't an open circuit... which would indicated that there was either a broken or missing bulb. When it does this a normal filament bulb is too slow to light up, and it will appear to be off, when a LED is introduced in to this circuit it flashes because the LED reacts much quicker.
8th Dec 2016 11:05am |
