Home > Technical (L322) > Terrain Response - Snow
Woldtopper
United Kingdom 2008 Range Rover Vogue TDV8 Stornoway Grey
During this bad weather I have been using my 2009 TDV8 with the Terrain response set to the Snow setting, at first whenever I switched the engine off and later re-started, it returned to the normal setting however it now goes to the snow setting whenever I start the engine even when it was left in the normal setting before switching off. any sugestions how I get it to stay in the normal setting until I want to change it?
Post #40778 4th Dec 2010 11:28am
Sportex
England 2008 Range Rover Vogue TDV8 Stornoway Grey
I have noticed the very same, can only assume its auto cos temp at - degrees No body told me there would be days like these
L Reg dark purple/burgundy sort of Disco
R Reg very red disco
Bright Silver disco TD5
Sort of bright girly powder blue disco TD5
Gone (a while back) 1999 P38 4ltre Autobiography. 13 miles to the gallon, 10,000 miles to the engine
Gone MY06 RRS HSE Rimini Red
Gone MY10 RRS HSE Purple
Gone 2007 TDV8 Vogue OF Stornoway Grey (In Love again)
2011 4.4 TDV8 Vogue Baltic Blue
MY66 VOGUE TDV6 3.0 Red
Post #40812 4th Dec 2010 1:52pm
ukrangie
It depends on how frequently you drive your car. If you use your car as a daily driver, then the Terrain Response will remember the last selection you made. From pg. 197 of the manual
Quote:
If the starter switch is turned off with a special
program selected, then the system will
remember for approximately six hours which
program was selected and return to that
program once the starter switch is turned back
on
That being said, the same page also notes
Quote:
It is possible to have the Terrain
Response system configured so that if
the Grass Gravel Snow program is
selected, and the starter switch is turned off,
the system will not default back to the General
program after the six hour period. The Grass
Gravel Snow program will remain selected until
it is deselected manually. Consult your Land
Rover Dealer/Authorised Repairer
 Paul
Twitter - Facebook
Post #40846 4th Dec 2010 6:57pm
Woldtopper
Thanks for that ukrangie, it is time related and now seems to have sorted itself out! Im getting a set of Goodyear MTR's fitted next week so I expect that will be the end of the snow!
Post #40902 5th Dec 2010 10:05am
Quite - just bought the wife a 4X4 and then the snow stops..... Big Cry
Post #40907 5th Dec 2010 10:49am
ukrangie
My pleasure. When I first noticed it, I thought perhaps the car was being clever or it was temperature related. Paul
Twitter - Facebook
Post #40911 5th Dec 2010 11:11am
SteveMFr
Site Sponsor
Just as an aside: MT's make poor snow tires (other than in snow up to your eyeballs). What makes a good snow tire is not big lugs but sipes (the little squiggly cuts in the tread - wikipedia has a good explanation). The big lugs on an MT reduce the amount of rubber on the road or on snow and actually make even worse snow tires in average 1-2" snows or on packed snow streets than summer tires. MT's can only help in very deep, unplowed snow.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #40929 5th Dec 2010 2:04pm
