Home > Maintenance & Mods (L322) > new battery ...95ah or 110ah
Page 6 of 12 <123 ... 567 ... 101112>
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
M44K TS wrote:
Richcl wrote:
Also, when you put bonnet in vertical position, look at hinges, you'll see two littel brackets that lock the bonnet in the upright.
Never noticed those before!
Look closely at the bonnet hinges, you'll see to smaller brackets, that rotate and locate on to two studs.
Post #40633 3rd Dec 2010 8:41am
M44K TS
So like my old 850 T5 Volvo then, you could do the same with that. 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #40634 3rd Dec 2010 8:47am
GJOB
2005 Range Rover Vogue SE Td6 Java Black
I've managed to get the i1 Varta Silver Top for £119 from a battery centre in Nothampton.
110AH, 920CCA.
Me thinks I got a good price, I can collect it too so have the peace of mind if anything goes wrong.
I'm not sure it actually is the battery causing the my problems (no FBH, HEVAC switches itself off, hazards come on when putting the key in etc). defintitelt electrical issues and since the car is 5 years old it will be due anyway.
lets hope it warms up over the weekend Wink
Post #40637 3rd Dec 2010 9:07am
well you have got the correct power battery Thumbs Up , just remember to put the steering hard left ,then right when you've connected it.. ... - .- -.
Post #40655 3rd Dec 2010 11:31am
GJOB
Did I miss the battery fitting guide in the wiki?
Post #40682 3rd Dec 2010 2:09pm
scarey wrote:
and the thursday top tip is, dont drive with the bonnet in this position..
but you could try a spot of land sailing (backwards or forwards, but I would reinfoce the bonnet for forwards)? .
Post #40728 3rd Dec 2010 5:15pm
Richcl
Changed battery (again) this morning, so took a pic of hinge in the locked upright position.
Post #40825 4th Dec 2010 2:56pm
GJOB
All done Very Happy
It took a bit of wiggling as the 110ah is about 50mm longer then the OEM.
it didn't fix my FBH problem though so that will need dealer assistance me thinks. Good jo it's under warranty. Wink
Post #40841 4th Dec 2010 5:15pm
did someone mention jo?... Big Cry ... - .- -.
Post #40859 4th Dec 2010 7:15pm
GJOB
who's Jo? before my time?
Post #40864 4th Dec 2010 8:31pm
you really dont want to know. Wink ... - .- -.
Post #40873 4th Dec 2010 9:07pm
Hmmm... the Tayna site (http://www.tayna.co.uk) has two car fitment guides, one standard and one updated. When I ran the guide for FFRR Diesel:
The standard guide gives the type 610 200 Varta I1 with 920 crank and 110Ah @ £115.99 + £10.43 delivery (VAT inc)
Dimensions: 393 x 175 x 190 mm
whilst the updated guide gives the 019 type Varta H3 with 830 crank and 100Ah @ £98.99 + £9.73 delivery (VAT inc)
Dimensions: 353 x 175 x 190 mm
From what has been written above the I1 will fit, but is it worth the extra £25?
http://www.carbatteryshop.co.uk also offers the Varta I1 by default for the FFRR at the same price.
Also I looked in Halfrauds today. Their battery had a crank of 550/580 Confused .
Post #41047 5th Dec 2010 11:29pm
GJOB
I can recommend the i1 having fitted one yesterday. It's snug but it makes all the difference, £25 divided over the next 5 years or so isn't really worth worrying about imho.
920cca is what it's all about.
S Very Happy
Post #41051 5th Dec 2010 11:39pm
Yep, as much as an aide memoire for me but also for others.
Have bought the I1 from Tayna. Good webshop, can use paypal too Smile .
Post #41104 6th Dec 2010 11:04am
Well, great service from Tayna - it arrived the next day, but needed to wait for some daylight at the weekend before fitting. When I got it out of the packaging I thought, "no way is this going to go in!". However it does fit, and if you organise all the cables out of the way, it just slots straight in, and then a little jiggle to line up for the clamping bolts.
Made much easier by putting the bonnet in service position, and because I'm a short-arse, I stood on a box to give me better leverage when taking out the old and putting in the new. These Censored are heavy so good manual handling practice is a must.
The battery that came out was a no name "Master" - "Charging Bull" with crank of 680. No wonder.
Only trouble I did have was with refitting the negative cable - just long enough and you have to squeeze it down the side of the battery to get it to fit down on the terminal.
Starting up the car showed an immediate change...
Instead of rrr.......rrr.......rrr......rrr......start
it was rrr.rrr.rrr.start
(meant to indicate how much faster the starter motor was turning)
I got an air suspension inactive message, but guess this will go away once I have started and stopped the car.
Now I can add my old battery in series to my solar panel setup at my beachhut. Smile .
Post #41850 11th Dec 2010 11:23am
