Home > Maintenance & Mods (L322) > new battery ...95ah or 110ah
Page 7 of 12 <123 ... 678 ... 101112>
i bet you find that it drives better as well JOE, might be in the head but it seems to..i'm 6 foot tall and found that standing on a stool does help putting the battery in .. ... - .- -.
Post #41860 11th Dec 2010 1:28pm
td6 vogue
United Kingdom 2004 Range Rover Vogue Td6 Java Black
GJOB wrote:
All done Very Happy
It took a bit of wiggling as the 110ah is about 50mm longer then the OEM.
it didn't fix my FBH problem though so that will need dealer assistance me thinks. Good jo it's under warranty. Wink
GJOB. Let us know what the dealer said the problem was! Thanks.
Post #41866 11th Dec 2010 3:45pm
GJOB
2005 Range Rover Vogue SE Td6 Java Black
td6 vogue wrote:
GJOB wrote:
All done Very Happy
They confirmed my FBH is FUBAR Sad They're on to the warranty co. to see if itsd covered.
I'm going to get them to give me the old one back anyway so I can maybe get Webasto involved.
Post #42231 13th Dec 2010 11:17pm
M44K TS
Just replaced my battery with a Bosch Silver something or other, 920CCA/110Ah 5 year guarantee for £161 inc. VAT
I never realised how useless my old battery was, was an 88Ah/680CCA and it was already down to 11v after sitting for 2 days. Needless to say, the starter motor turns the engine over twice as fast, no air suspension inactive warning due to the low voltage and the interior lights have stopped pulsing every few seconds with the engine running.
Definitely the most worth while thing I've done. Hopefully no more worries abot the car not starting after being left a few days. 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #46657 19th Jan 2011 8:28pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Their has to be a market for all these batteries that are not man enough for Range Rovers, but fine in other applications. Confused
Post #46661 19th Jan 2011 8:45pm
theres obviously a scrap value but i've got my old one in the garage for testing bulbs and a back up 'jump start' battery for my family and neighbours 'lower class' cars. Very Happy
Post #46714 20th Jan 2011 10:45am
Dogman
United Kingdom 2007 Range Rover Vogue TDV8 Zermatt Silver
Ok Guys, so feeling pretty 'kin stupid here........
2007 RRV TDV8 RHD
Varta 610 402 092
Just tried replacing my battery with the varta, as per thread, and the B*st**d thing will not fit.
Fits on the tray OK but there is not enough clearance to fit the +tve lead to the terminal!!
On the +tve lead where the terminal clamp is there's a rectangular box (fuse?), is this the norm as everyone seems to have had no problems with theirs (or is this a post 2006 issue i'm experiencing?)....it's this unit that's about 7mm too wide to fit in the battery compartment (width ways) and is stopping me fitting the varta.
Any help / advice would be very much appreciated indeed!! Big Cry
Post #101042 10th Jan 2012 5:43pm
Definately the right size for 2002+ but not sure about post 2006 Facelift models.... Confused
Just checked my 2006 Vogue SE SC which has original Land Rover part and there is about 4-5 inches of clearance above the positive terminal block!
Not sure how yours can be such a tight fit?
Post #101043 10th Jan 2012 5:48pm
Dogman
Hi Gary
Thanks for the quick reply, hope you are keeping well Thumbs Up
It all fits OK but the +tve won't connect, do you know if the +tve usually has this box/fuse on the end?
Thx
Post #101044 10th Jan 2012 5:56pm
Yes it does - this is mine (Just taken)
Post #101045 10th Jan 2012 5:59pm
Dogman
Hi Gary
Mine looks like this....do you notice how the block is positioned down the left hand side of the battery?
Post #101047 10th Jan 2012 6:19pm
simon1233
Dogman
I have just fitted a 110 Bosch battery and had similar issues as you describe with the positive terminal. I managed to get mine on after I had used a couple of big levers to move the battery as far over to the outside as possible Thumbs Up
Post #101061 10th Jan 2012 7:35pm
Land Rover Battery must be thinner? (less wide)
Post #101063 10th Jan 2012 7:39pm
Johnte
2007 RRV TDV8 RHD
Varta 610 402 092
Is the "rectangular box"you are talking about, the Pyrotechnic Charge
Post #101066 10th Jan 2012 8:08pm
Dogman
Hi Simon
I did think about the clarkson approach (read hammer) but was a bit concerned as where the cable attached to the box there is exposed cable (looks as though it's not stretched or pulled) but was mindfully that it would be resting against metal chassis- could isolate it of course. So big lever and push battery to the right then?
Hi Gary
Yes the OE LR unit has about 2-3" of play at least, I went for the Varta 110ah as had a few cold morning non-starts......thanks for the photo by the way, sorry was flat out at work when I was replying earlier ( Confused Contradiction maybe).
Hi Johnte
I wondered that, maybe, it does say fuse but to be honest when I was changing it today I was short on time and goal focused so just tried different ways to get around the issue.
If I get a chance tomorrow I'll note part numbers and text on item just so we know and maybe I'll try to 'tease' that battery in as Simon has suggested as it's about 5-7mm clearance needed. Would fit fine if I raised the battery by 2" but then the clamps will be too short which would mean extending the studs.....
Thanks to everyone who's helped, most appreciated.
Post #101079 10th Jan 2012 9:53pm
