![]() | Home > Maintenance & Mods (L322) > new battery ...95ah or 110ah |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
Look closely at the bonnet hinges, you'll see to smaller brackets, that rotate and locate on to two studs. |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 ![]() ![]() |
So like my old 850 T5 Volvo then, you could do the same with that. 2006 Mercedes CLS
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35634 ![]() ![]() |
well you have got the correct power battery |
GJOB Member Since: 24 Oct 2010 Location: Northants Posts: 131 ![]() ![]() |
Did I miss the battery fitting guide in the wiki? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
but you could try a spot of land sailing (backwards or forwards, but I would reinfoce the bonnet for forwards)? . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
Changed battery (again) this morning, so took a pic of hinge in the locked upright position.
All done |
did someone mention jo?... |
who's Jo? before my time? |
you really dont want to know. |
Hmmm... the Tayna site (http://www.tayna.co.uk) has two car fitment guides, one standard and one updated. When I ran the guide for FFRR Diesel:
I can recommend the i1 having fitted one yesterday. It's snug but it makes all the difference, £25 divided over the next 5 years or so isn't really worth worrying about imho. 920cca is what it's all about. S ![]() |
Yep, as much as an aide memoire for me but also for others.
Well, great service from Tayna - it arrived the next day, but needed to wait for some daylight at the weekend before fitting. When I got it out of the packaging I thought, "no way is this going to go in!". However it does fit, and if you organise all the cables out of the way, it just slots straight in, and then a little jiggle to line up for the clamping bolts.
