![]() | Home > Maintenance & Mods (L322) > battery flat and super locked |
Diddley Member Since: 13 Apr 2016 Location: Notts Posts: 20 ![]() ![]() ![]() |
Can some one please help me as I am locked out of the car 4.4tdv8 2011 and I can't get in the battery seems flat! |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3786 ![]() ![]() ![]() |
Have you got a tow bar fitted?
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8354 ![]() ![]() ![]() |
Will it not open with the key in the door... or... if you have a tow pack you can charge it up through the plug...
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35465 ![]() ![]() |
nice one Mark, i've wiki'fied this.. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8673 ![]() ![]() ![]() |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 760 ![]() ![]() ![]() |
thats brilliant, now i might get up enough courage to lock mine, knowing that if i cant unlock it i still have a chance RR 2005 4.4 petrol
Henda Member Since: 02 Aug 2018 Location: Gateshead Posts: 282 ![]() ![]() ![]() |
Had that type of manual lock cover on my disco it's worth opening and trying out also a good idea to use graphite grease or similar to prevent the lock seizing , coz you just know when it's needed it will be seized |
raced out to look at mine this morning, its not the same |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6414 ![]() ![]() |
but you have a manual lock - make sure it works - (should set off alarm, just put key into ignition and turn on) .
"but you have a manual lock - make sure it works - (should set off alarm, just put key into ignition and turn on)"
by the manual lock, do you mean the lock in the drivers door.
Diddley
babknob Member Since: 07 Jun 2019 Location: Hastings Posts: 2 ![]() ![]() ![]() |
Same happened, no battery and lock would not open. No alternative lock on passengers door. Bit of a fiddle but get a spare charged battery or power source i.e. another vehicle. Get under car and locate alternator. You will have to undo some body parts like the front under-shield. Take off alternator lead and connect to + battery terminal and - to chassis. This will set off the alarm for a few seconds but will also open the door. Then you can get in and pop the bonnet and connect up. |
