Home > Maintenance & Mods (L322) > battery flat and super locked
Page 1 of 3 123>
Diddley
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Baltic Blue
Can some one please help me as I am locked out of the car 4.4tdv8 2011 and I can't get in the battery seems flat!
Post #395222 9th Jul 2016 3:00pm
Baltic Blue
Have you got a tow bar fitted?
You can put a charger on via the white capped socket.
Post #395235 9th Jul 2016 3:47pm
Will it not open with the key in the door... or... if you have a tow pack you can charge it up through the plug...
Probably other ways, don't know the layout at the front on the later ones.... Pete
Post #395236 9th Jul 2016 3:50pm
to open it with the key inside the fob
on the passenger door there is a small hole under the handle on the part where the lock should be.
insert your key in here and remove the painted cover. under this is the actual lock.
insert key and open.
folks think that the hole underneath is the lock it isn't, you need to remove the cover and it will give access to the keyhole. the key should open it even if super locked. I know I've just done it on mine to see how it worked. Thumbs Up Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #395245 9th Jul 2016 4:31pm
nice one Mark, i've wiki'fied this.. Thumbs Up
edit, sorted pics as well.. ... - .- -.
Post #395256 9th Jul 2016 4:59pm
Post #395260 9th Jul 2016 5:02pm
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
thats brilliant, now i might get up enough courage to lock mine, knowing that if i cant unlock it i still have a chance RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #512185 15th Apr 2019 8:59pm
Henda
United Kingdom 2006 Range Rover Vogue TDV8 Zambezi Silver
Had that type of manual lock cover on my disco it's worth opening and trying out also a good idea to use graphite grease or similar to prevent the lock seizing , coz you just know when it's needed it will be seized Thumbs Up
Post #512192 15th Apr 2019 10:01pm
knares
Thumbs Up RR 2005 4.4 petrol
Post #512201 16th Apr 2019 1:20am
knares
raced out to look at mine this morning, its not the same Big Cry Big Cry RR 2005 4.4 petrol
Post #512363 17th Apr 2019 12:23pm
but you have a manual lock - make sure it works - (should set off alarm, just put key into ignition and turn on) .
Post #512371 17th Apr 2019 1:45pm
knares
"but you have a manual lock - make sure it works - (should set off alarm, just put key into ignition and turn on)"
O
i will have to learn about that RR 2005 4.4 petrol
Post #512456 18th Apr 2019 12:51am
knares
by the manual lock, do you mean the lock in the drivers door.
if you do, i did lock the door that way once and couldn't unlock it
some how my son managed to unlock it and i haven't been game to lock it since RR 2005 4.4 petrol
Post #514355 5th May 2019 12:33pm
knares
Diddley
how did you go RR 2005 4.4 petrol
Post #514737 9th May 2019 4:54am
babknob
United Kingdom 2004 Range Rover Vogue 4.4 V8 Bonatti Grey
Same happened, no battery and lock would not open. No alternative lock on passengers door. Bit of a fiddle but get a spare charged battery or power source i.e. another vehicle. Get under car and locate alternator. You will have to undo some body parts like the front under-shield. Take off alternator lead and connect to + battery terminal and - to chassis. This will set off the alarm for a few seconds but will also open the door. Then you can get in and pop the bonnet and connect up.
Post #517693 7th Jun 2019 2:03pm
Page 1 of 3 123>
