Home > Maintenance & Mods (L322) > battery flat and super locked
Page 2 of 3 <123>
@ babknob
I presume you needed a working key to unlock? .
Post #517700 7th Jun 2019 3:48pm
babknob
United Kingdom 2004 Range Rover Vogue 4.4 V8 Bonatti Grey
No, mine popped the lock so I could just open without using the key. Of course lost all the codes and had to get a reset but it got the car moving.
Post #517731 7th Jun 2019 8:27pm
That is a worry - security wise..... Shocked .
Post #517732 7th Jun 2019 8:30pm
Adriansj
United Kingdom 2008 Range Rover Autobiography TDV8 Barolo Black
Baltic Blue wrote:
Have you got a tow bar fitted?
You can put a charger on via the white capped socket.
How, Can you explain in more detail please?
Post #692350 11th May 2024 1:22pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi, Not sure about white capped socket as I have a 13 pin tow kit, but you can charge the battery via the unswitched +12v & Gound pins of the towing electrics.
In the case of the 13 pin that would be across 9+ve & 13-ve.
But do not put on high charge as the link is fused, you should only trickle charge it or you'll blow the fuse, (or worse) and then your up Sh*t Creek.
Check what type of socket you have and google for the pinouts if it's not an ISO 13 pin.
Andy Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #692351 11th May 2024 2:13pm
Baltic Blue
Check the forum shop, they sell a range of plug in adapters .
I used one to make up a handy charging board, but mine is the older white cap version.
Post #692352 11th May 2024 2:24pm
AndyRoo
Hi,
I made a weatherproof charger from a weatherproof box from Screwfix, my old bike charger with a 13 pin towing plug and parts I had lying around, works a treat.
Andy
Post #692353 11th May 2024 2:54pm
Adriansj
I could not find anything on the shop so what if I just get an 8 pin from a caravan shop and strip the wires and connect to my battery charger but just use the lower 6v option to get enough juice into the battery for a few hours. If this fails I'll call AA or smash a window to pop the bonnet. Anyone know the layout of the 8 pin adaptor?
Thanks,
Adrian
Post #692355 11th May 2024 3:02pm
AndyRoo
They should be 7 pin, here's a generic diagram from the internet.
https://www.altecautomotive.co.uk/twin-tow...-984-p.asp
Someone should be able to advise on what pins to use, I've not got this type Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #692361 11th May 2024 3:18pm
AJGalaxy2012
Thanks,
Adrian
That wont do it, you need 13.8v and above to charge the 12v battery.
Use pin 3 (-ve) and pin 4 (+ve) BMW i3 Electric Car
2006 VW Touareg 3.0 TDi V6
Post #692368 11th May 2024 4:36pm
Red Hot one
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
As is probably in one of the replies, jack the Right hand front of the car up, connect charger to the starter motor positive terminal and a good chassis earth and you are good to go.
Post #692369 11th May 2024 4:43pm
Adriansj
Cant really understand that diagram but I'm assuming pin 4 for the live and no idea about the negative?
Post #692373 11th May 2024 5:11pm
Earth = negative
But TBH - if you have to ask then be very very careful Laughing
And that's the pinout for the auxiliary (white) socket for twin electrics. If you only have a single 7 pin socket, you're out of luck.
Post #692377 11th May 2024 5:49pm
Adriansj
Ok so I have live to pin 4 and negative to pin 3 which seems correct.
Post #692380 11th May 2024 6:12pm
AJGalaxy2012
correct BMW i3 Electric Car
Post #692388 11th May 2024 7:20pm
Page 2 of 3 <123>
