![]() | Home > General > What Did You Do In Your Full Fat Today |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2685 ![]() ![]() ![]() |
2 x keys refurbed
jfb1977 Member Since: 29 Apr 2012 Location: Bury St Edmunds Posts: 563 ![]() ![]() ![]() |
Fitted some alloy pedals.
LROMAD Member Since: 10 Oct 2015 Location: Cheshire Posts: 54 ![]() ![]() ![]() |
Took her to my Indy to have them look for fault codes ..NON found , happy days |
Offroader50 Member Since: 06 Jul 2016 Location: Bewdley Posts: 5 ![]() ![]() ![]() |
I took mine to a garage as its blowing black smoke and a little worried about the outcome?? hence why I joined FullFat today..... had a Landcruiser for 10 years - No problems, had this 11 months and it has now decided to test how deep my pockets are..... what have I done??? someone convince me I've bought a good motor...ha ha! |
Fitted a boot liner so that these two chancers could get a ride.
steeplejack Member Since: 11 Apr 2016 Location: Gloucestershire Posts: 19 ![]() ![]() |
I don't want to be getting stuck in a wet grassy field and keen to get out on some lanes so new tyres were in order.
DrAvalanche Member Since: 26 Mar 2016 Location: Leeds, West Yorkshire Posts: 19 ![]() ![]() ![]() |
Swapped the wiper blades over for the flat blades - much quieter |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 792 ![]() ![]() ![]() |
Try a basic repair first. Empty, dry out with hair dryer and then seal all around the join with a bead of superglue. Check vent pipe. Worked for me. |
Yeah I've looked at it and it looks as though a temporary repair has already been tried before and the outer lens cover is a bad fit. Not worth a second attempt
Busa1400 Member Since: 05 Oct 2015 Location: Leeds Posts: 112 ![]() ![]() ![]() |
I went to the Great Yorkshire Show 2011 Range Rover Vogue SE |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
Made friend with Mr Zebra this morning!
Declan303 Member Since: 08 Dec 2015 Location: Meath Posts: 151 ![]() ![]() ![]() |
Replaced the rocker cover gaskets along with all the rubber washers on the retaining nuts and again thanks to the great write up on this forum, made the job a lot easier. |
frikkadel Member Since: 09 Mar 2016 Location: joburg Posts: 56 ![]() ![]() |
what did i do with my ffrr this weekend. Well have only had this a few days so, saturday morning, went for breakfast at wimpy. pain from my tooth was getting bad , so off we went to the dentist. Quick root canal and then off we went to the game reserve. There was loads of dust, and only saw some buck and ostrich, so after 10kms , we hot footed it home. No photos of us in the reserve, as i aint getting out. There are lions and who knows whats hiding in the bush.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
cleared the dpf out.... ... - .- -.
