![]() | Home > My Range Rover > The New SHINEY thread.... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35648 ![]() ![]() |
ouch!!! ... - .- -.
Mikeinatruck Member Since: 14 Apr 2016 Location: Dumfries Posts: 50 ![]() ![]() ![]() |
Autoglym high definition wax is awesome....
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Don't think it will buff out though |
All shiny and new again!!
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
That sounds like a good price. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
That was a good price |
Car came back from the dealer after having the new front strut fitted
Just had a thought,
Ok so back from the dealer after a look at the squeaky belt and damp shock. Not bad enough to need changing yet! We shall see how it goes at the MOT next year. They also checked the battery and charging system which was all OK. The shock was deemed not gone enough for the warranty company to change at this point, though later it may be, the squeaky belts were only a tiny bit noisy at cold start up. The tensioner probably needs doing, but they reckon that when it gets worse they can justify to the warranty co swapping all the pulleys! (£1200) which includes the crank pulley, though god only knows why that would need changing as it is just a metal disc which bolts to the crank!
Today I swapped out the ARB drop links, what a PItA.
good price on the steps...seems loads are buying these |
well the steps are here awaiting fitting on a nice day........
Ok so it's been in today to diagnose the leaks, the steering just needed nipping up, they diagnosed a leaking intercooler pipe on the secondary turbo and have finally conceded that the oil pickup is leaking.
Have put the EBay, tune2air in last night. Works faultlessly picks up the iPhone and I get all the music on the touch screen. There is nothing that can't be fixed with a hammer😜😜
