Home > Technical (L322) > Westafalia key
ndg
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Westafalia key
Another request for help from a new owner.
Could someone post a picture of the key for their westafalia towbar (or PM)? I've got a bar (with key no.) but can't remove the swan neck and a photo would help identification at the key cutters.
Thanks
Post #381968 13th Apr 2016 9:52am
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
Is this what you are looking for?
I know Westfalia will supply new keys if you have the number if thats any use and there seems to be plenty online who will supply the key for under a fiver if you have the code - these ones start 2W
Regards
Nick
 Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #381973 13th Apr 2016 11:18am
ndg
Thanks for that. The lock only has a three digit code, so I assume it would be 2Wxxx.
Post #381980 13th Apr 2016 11:49am
nicksaab
No unfortunately the the key numbers are 4 digit starting 2W** so l don't think you have the key number.
I will go out and check the lock number on mine and get back to you Current Fleet:-
Post #381984 13th Apr 2016 12:25pm
nicksaab
Ok the lock number and the key number are different on mine too
The lock number is 5 digits and the key number 4 digits - will PM you seperately to help more
Cheers
Nick Current Fleet:-
Post #381986 13th Apr 2016 12:32pm
ndg
Thanks!
Post #381987 13th Apr 2016 12:32pm
johnboyairey
the key is often found, in the boot storage bin, where the hook normally is stored. if your hook is on, you might not be aware it should be in front right of luggage area in a flip lid box. go to westfalia site, and send decent picture of the key slot, thay can send you a key, maybe with proof you own the car.
Post #381988 13th Apr 2016 12:35pm
ndg
Unfortunately the car had the armature, but no bar. I've acquired a bar on eBay, but it came (knowingly) without a key, just trying to sort that out!
Post #381991 13th Apr 2016 12:41pm
the key number probably corresponds to the lock number on some database somewhere, a good pic of the barrel and an email to westfalia should sort it.
Be aware though, if the ball has been in the socket for some time it might not be as detachable as you think. Whistle There is nothing that can't be fixed with a hammer😜😜
Post #382005 13th Apr 2016 4:00pm
miggit
I managed to get a replacement key for my Bosal / Oris hitch on the Mercedes ml... the number on the hitch is nothing like the number on the key Shocked That's is probably to stop some little Censored running off with your hitch.... anyway I just had to ping Germany with an email and they told me which key number I needed so that I could order it from Bosal in Preston Shocked Bloody long winded way of doing things Laughing
From the Westfalia website
Quote:
Keys for detachable towbars
I HAVE LOST THE KEY FOR MY DETACHABLE TOWBAR. WHAT CAN I DO?
You should always keep a record of the number on your key when you receive your Detachable Towbar. The key number is stamped into the head of the key. With this number you can get a replacement from your local Westfalia Fitting Partner or directly from us.
If you do not have a record of your key number, contact your local Westfalia Fitting Partner who will be able to request a Master Key Set from us. This contains all of the available keys. When you receive the Master Key Set try out the keys until you find the one that fits. Using the number on the key you can then order a replacement from your local Westfalia Fitting Partner or directly from us.
When you have finished with the Master Key Set please return it to your local Westfalia Fitting Partner or send it directly to us.
I don't know where abouts in Warwickshire you is, but there are 3 stockists in the Warwick area Thumbs Up
https://www.westfalia-automotive.com/uk/stockists/ Yesterday I couldn't spell Engineer... Today I are one!
Post #382045 13th Apr 2016 9:53pm
mjdronfield
I have no key for mine. I have the number. Westfalia want £22 for a key.
I'll leave mine fitted for now ! 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #382144 14th Apr 2016 4:42pm
nicksaab
You can get the key cut for less than a fiver online if you know the key number -just google Westfalia key cutting Current Fleet:-
Post #382196 14th Apr 2016 10:37pm
miggit
Shocked Shocked How Much Shocked Shocked
I paid a tenner for my Mercedes Key, and I thought that was a bit OTT...... But £22? Is it gold plated? Yesterday I couldn't spell Engineer... Today I are one!
Post #382197 14th Apr 2016 11:39pm
ndg
Well I went to my local Westfalia towbar dealer this afternoon. Apparently there is only one master key set which has a waiting list.
Whilst I was there he tried the three keys he happened to have lying about. None of them fitted, so he went to get the one from his van, which low and behold worked! I don't think it's quite the right one as it needs a bit of a wiggle, but I've got a code now so have ordered a couple of the web (he suggested this anyway).
Hopefully the copies will work.....
Post #382287 15th Apr 2016 5:44pm
mjdronfield
Just ordered one off the bay for £3.60. My number doesn't start 2W, but 5 numbers, so I hope what I was told to order is correct... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #382290 15th Apr 2016 5:58pm
